Old 04-07-2015, 09:21 PM
What harness are you running? Engine and vehicle?
Mount the relays close to your battery source. I like to mount them near the fans around the horn relay or junction on Chevy's.
Old 04-07-2015, 09:30 PM
malo69 malo69 is offline
Its a 69 Camaro with a ls2 (gto) harness is a after market with the normal deletes on ecm battery was relocated to the trunk
Old 04-07-2015, 11:37 PM
What brand engine harness or who put it together. Did it come with a relay block?
There should be a fan 1 and 2 wires from the PCM.
You can run a 10g wire from the starter BAT+ to a junction block or circuit breaker for the relays. Mount them up on the radiator support.
Old 04-08-2015, 07:22 AM
dhutton dhutton is online now
Here is one option. Not the lowest cost but gives you dual speed fans and an option of A/C control.
http://shop.bp-automotive.com/Univer...rness-1022.htm
Old 04-08-2015, 08:55 AM
Pretty dang cheap if you ask me -- given what I pay for SPAL relays @ $34 a piece!
Old 04-08-2015, 10:55 AM
It is a good value. I bought one of these and it looks well made.
Old 04-08-2015, 11:39 AM
well if your gonna roll the dollars might as well break out "the Player"! Or as Weld like to say the "da Playa"
http://www.entropyrad.com/wiring-harnesses.html
Everything that Uncle John needs.
