Old 04-10-2015, 08:04 AM
rickpaw rickpaw is offline
Holley sells an AC on solenoid that bumps the idle speed up when the AC is on. You can use the fan on signal to trigger the solenoid. Holley P/N 46-74.
Just curious, why would an increased load on the electrical (with the fans on) cause the idle speed to drop?
Tu Ho
Old 04-10-2015, 08:48 AM
carbuff's Avatar
carbuff carbuff is offline
My car does the same. It's the alternator kicking in to supply the increased load. My Holley HP controller bumps up the IAC position quite a bit to compensate. And then when the AC kicks on, it's even worse. It was a little tricky to get all that working correctly as well, so it's not just a carb problem.
Old 04-10-2015, 10:04 AM
Neil B Neil B is offline
From what I have read, that solenoid is not powerful enough to bump the idle on it's own. You have to blip the throttle and then the solenoid will hold it at the higher idle. So I'd have to blip the throttle every time the fans engage.
Old 04-11-2015, 03:35 PM
gray86hatch gray86hatch is offline
Use a pwm to control the fan. On dads car with this you could not tell the fans were on. Almost never need to run at full speed.
On a normal drive on 80 degree day the fans dont come on unless stopped. I have the low at 195 and high at 205. Norm right on the tstat at 195
Tim
86 mustang
454 lsx FTI ls3 mast 4500 9.24 144 pump gas dragradials
79 z28 29k org miles. DSE suspension Bonspeed GTB
