  #31
Old 04-19-2015, 06:45 PM
E.rodz's Avatar
E.rodz E.rodz is offline
This is a small example of how stupid I can be at times! this pict. is from a couple of years ago pulled a ford 9" out from behind the garage and cut all the brackets off to make it fit in the chevelle chassis after more fitting found out the pinion was offset 2" so it was not going to work! ended up ordering a new rear from Moser with all the brackets welded on to fit s a direct bolt in! sweet right?
fast forward to present time. lets cut the brackets off the rear to make a custom 3 link and lets make a custom frame as long as were at it!
my name is Eric Hokenson I have a dream of building ten of the coolest hot rods out of my home shop wish me luck I am going to need it! - more pics on my web site www.erodzcustoms.com this is just for fun and i am NOT looking for any more work!
Thank you supporting sponsors! without you guys there is no way I could do this myself !
Modern automotive performance,Ring bros.,Yank convertors,extreme drive systems,Cj tunes,race coatings stainless works,Modern Automotive Performance.all of these shops have the experience to get your car to the top.
