Old 04-20-2015, 12:14 PM
cwylie cwylie is offline
What should the gap at the bottom of the door to the rocker be?
Old 04-20-2015, 02:05 PM
I go by the body lines and top of the door then fill/adjust the bottom gap last. 1/4" without paint.
Old 04-20-2015, 08:42 PM
Sonar Chief's Avatar
Question
That is what I have done so far, the AMD door skin fits better to the OEM quarter than it does the AMD quarter, grrrrrr. What concerns me is the distance from the front to back, ie... where to position the door so its not too close to the back but still closes with the striker in place, and ... the door still closes w new weatherstripping.
Thanks for commenting ....
Old 04-20-2015, 11:08 PM
snappytravis's Avatar
snappytravis snappytravis is offline
Originally Posted by Sonar Chief View Post
Those were old pixs with the skins replaced to see how the door fit against the GM quarter ...and the car is now sitting on its suspension, trying to get things lined up and gap the door-quarter panel.
I did both door skins at the same time, so no reference there, the quarter panel is still on the pass side but the AMD skins are not the same as the GM ... grrrrrr!
I'll line up the front on the rocker and see if that helps. Do the professional shops gap everything W/O weatherstripping? And then just squish it when the door is closed?
Thanks for commenting .... any other ideas or pictures of 67 gaps?
Michael
I think someone else posted to line the doors up without the strikers. That is how I do it, The weatherstrip always seem to be tight when a guy replaces them. I like to line the doors up without the weatherstrip in. I used amd qtrs, and skins on my 69 I had to cut the qtr at the top. Just like your picture and angle it back a little to open the top of the gap. I also had to weld a few spots on the edges of the doors then go back and file or grind them to make the gaps somewhat even and what I thought was good. I worked at a Toyota dealership for 10 years and this car drove me nuts for fit.. I don't see a lot of cars that people spend the extra time to get stuff to fit nicely. Pretty much rule of thumb would be to get bottom and rear gap good. Then install fender and pray it lines up good. If not start welding the edge.
