Old 04-21-2015, 10:08 AM
NOPANTS68 NOPANTS68 is offline
These types of things are already happening in the diesel world. When I bought my Cummins, I immediately bought a tuner, DPF delete and an intake. These mods resulted in a 5 mpg difference and a truck that is vastly smoother and more crisp while keeping the "tune" in stock power mode. Within 24 months of these kits being sold, the EPA was able to use many different channels of power to enforce the stopping of these kits being made and sold. You can no longer buy a DPF delete kit with a programmer that turns off the ridiculous "regen" fuel system. Pretty pathetic.
For clarity purposes- the DPF is a diesel particulate filter and the "regen" system is a pair of fuel lines and spouts that introduces raw fuel from the fuel pump into the cats to super heat them. The EPA's thought in mandating these types of systems was that the trucks would run cleaner because the cats would remain hotter during the truck's operation. You can all imagine what happens with the 6.7 system when raw fuel is sprayed into an idling truck's cat- it makes thick, black soot. This soot is trapped in the webs of the DPF, the DPF's increase in positive pipe pressure forces the ECU into limp mode, and the truck requires a $1500 "cleaning" which can only be done at a dealer. With this system disabled, my truck gets 16 mpg city and 22 freeway- towing my '29. Aftermarket- win again.
1929 Roadster Pickup
1961 Chevy Parkwood Wagon
1956 Chevy 210
Smithcraft Collision and Restoration
Newcastle , CA
