Old 04-23-2015, 07:07 PM
Chevy70 Chevy70 is offline
Originally Posted by Finch View Post
The rears are an 18 X 12 with a 5.5 BS and the fronts are 18 X 11 with a 6.125 BS if I remember it correctly.
Love my Forgelines and will have them on every build I do.
To fit the same setup on 19x12 would 5.5 also work? Most people seem to run a 7" BS... I do have ridetech 4link and dse tubs.
Old 04-24-2015, 05:51 AM
markss28 markss28 is offline
If your running stock rear width that will not work. You would need to narrow I'm guessing about 2" per side to get it at 5.5 BS. I have stock width rear and have 19x10 with 5.5 BS and it's tight. I think you would need about 7-7.5" BS with stock rear. Hopefully someone with more experience chimes in.
Never Stay Stock
Old 04-24-2015, 09:30 AM
Thank you, sorry yes forgot to mention stock rear end...
I know ppl run 7"... Wonder if 6.5" is possible
Old 04-24-2015, 11:10 AM
I think that would still put u at about 1" under the fender and out. U would rub like crazy. With an 11" rim yes but 12" I don't see that happening. If ur looking for a lot of lip. Just for reference I have about 3.5" of lip now. So not too bad. Other than that u will need to narrow the rear.
Never Stay Stock
Old 04-24-2015, 11:16 AM
Are you talking about the 5.5" backspace?
The 7" backspace on 12" wide rim on stock rear is a common size everyone runs without issues. I thought I might be able to squeeze the 6.5 ...
Old 04-24-2015, 01:10 PM
I think it just might sit a little too far out. It also depends on tire size. I measure from the brake face out to the fender and see how much room u have there. Then add the reminder to the inside and see how much room u have there. Also depends on ride height, if ur trying to tuck the tire or have the tire just right under the fender edge.
Never Stay Stock
