Old 04-25-2015, 09:35 AM
Transformer Transformer is offline
Default UMI Performance frame brace
Well, I just installed the UMI Performance rear shock tower brace part #3055... I like it, it fit perfect, and it makes sense. In the LSX El Camino my friend Greg is building, he has a completely different coil over shock set up and welded a cross bar to the frame where the shocks would normally mount and used his cross bar as the coil over upper mount point (very custom). I don't have that kind of room and my rear axle set up is not as custom as his... So, this UMI performance bar ties the frame together like his welded in coil over bar. I guess if a person really wanted to, they could weld this bar to the frame for additional rigidity - I won't be welding it though, simply because I like the bolt in application of this product.
This is really a no brainer for the the G-body... anything to stiffen the frame is good.
check out the install video here:
http://hotrodregal.com/umi-performan...y-frame-brace/
-Matt
Old 08-12-2015, 07:36 PM
Default Hotchkis stage 2 TVS install videos
Trying out the complete Hotchkis Sport Suspension Stage 2 TVS kit. Got some install videos and a few pics here - http://hotrodregal.com/hotchkis-susp...or-the-g-body/
Old 01-04-2016, 05:48 PM
Default Ididit steering column replacement for a 88-78 G-body
Talked to a few guys with bad tilt columns in their G-bodies. I had a column shift column for my G-body originally and swapped to a floor shift column. but there is a shifter linkage on the stock columns that is not used when using an electronic transmission (4L60e/4l80e). So my solution to these problems was a quick remedy from Ididit Inc. (click link for article and pics)
http://hotrodregal.com/ididit-univer...eering-column/
It's an option that not many G-body guys want to try since we have excellent columns usually... But what if you want something a little more crisp feeling than the stock column? Or (like my situtation) if you have a column shift car and want to switch to a floor shift column? Or if you just have a worn out stock column with a sloppy tilt...a Ididit Universal column or a custom built column is a good option.
hope this helps!
Matt
Old 01-22-2016, 03:10 PM
Default LSX El Camino
How about a look at Greg Cragg's LSX El Camino and the Ridetech suspension install (part 1)
http://hotrodregal.com/lsx-el-camino-riding-ridetech/
Old 11-16-2017, 06:08 PM
Default another El Camino ... and a new shop to build the Regal
http://hotrodregal.com/new-shop-new-el-camino/
built a new shop... helped my friend Gregwith his new El Camino- worth a look - Regal is up next.
