Old 05-04-2015, 09:33 AM
1976camaroguy's Avatar
1976camaroguy 1976camaroguy is offline
I've got the gauges, I ended up doing them this way with a Covan panel I textured and using the instrument panel that came with the bracket . I still have the bracket, but not using it at the moment.
The lens actually has a texture face and blends in with the bezel when the led's aren't on...pretty low key
One thing I did notice was that my colors were reversed on the check engine and brake warning. I used the housing supplied by new vintage and the led's were already glued in.
My kit came with a vertical lens and they sent me a horizontal lens free of charge so I guess there was a different layout between the two ...I've since swapped the colors around so it looks "normal". The check engine is amber and the brake light is red now.
1971 Camaro Pro-touring LS engine
