Old 05-08-2015, 07:10 AM
Smitty68 Smitty68 is offline
Originally Posted by paulk68 View Post
Looks awesome, I am about to start with my ridetech bolt in 4 link, how hard was the install? also how hard was getting the brackets welded on the rear end? Is it a stock width rear or did you shorten it?
It was a straight forward install. These old cars being assembled by hand gives a little bit of trouble from time to time with the cradle not seating into place like mine did. But with a couple of jacks and effort it slid right into place. The tabs weren't a big deal either. Just follow the instructions to a T and you will be fine. And the length on the rear end is stock with multi leaf perches made to order already welded up. I also went with the big ford ends for larger bearings and bolt in axles. If you want it narrowed I think they will build it to any lengths for no extra charge.
I called Matt and Kim at Matts Classic bow ties and they took care of me with everything.
