Old 08-02-2006, 06:54 PM
coolwelder62's Avatar
Default Camaro rack & pinion
Has anybody used the R&P from unisteer on their 67-69 camaro.Do you like it.And do you know what rack they use.
Old 08-21-2006, 06:37 PM
bwarren bwarren is offline
I've been pretty pleased with mine. The install had a few issues and now it looks like I need a new pump. The difference from the factory steering setup is EXCELLENT!!
Good luck!
Old 09-09-2006, 05:00 AM
bigtyme1's Avatar
bigtyme1 bigtyme1 is offline
I've noticed that alot of people are getting away from the rack and going back to the quick ratio box, Is there a reason for this? I need to make a decision myself.
Old 09-09-2006, 07:53 AM
68protouring454's Avatar
coolwelder, check out the early 80's mustang II rack, its what wayne due uses for his c4 subframe, you made your own c4 subframe right?
jake
Old 09-09-2006, 08:40 AM
Mean 69 Mean 69 is offline
If you are running a stock frame in the car, the newer steering boxes/rebuilt units from AGR, Flaming River, etc are a direct replacement, and offer terrific feel and performance. I haven't used the more recent rack units that are on the market, but I did use the Steeroids unit a ways back. Didn't really like it too much for the very short time I had it on the car. I went to an AGR box on my car when I did a motor swap, and am still running it. Awesome.
Downside for the boxes is that they are a bit heavier. So be it, I'll take simple, functional, and a bit heavier over complex, and uncertain any day.
If you are going to do a custom front frame, then there is little reason to consider anything other than a rack unit. Unfortunately, it's not as easy as just picking a Mustang unit out of the Summit Racing catalog and declaring victory, steering can be a fussy thing to get right. Lots of attention needs to be paid to packaging and insuring the unit is the correct width, and is located in the proper location.
Mark
Old 09-09-2006, 08:52 AM
as mark said, track width as well as lower control arm mounting points will push you where yo uneed to go as far as rack width, the deal is, you want the tie rod to swing as the same arc as the lower control arm, if it is not on the same arc/same length you will get bump steer(meaning the arc is different causing the tire to turn in or out thru susp travel)
some bump is ok, and most race guys like it to bump around .030 per inch of bump travel, meaning on a typical street car 3-4 inches of travel is all there is so something around .100 bump out is ideal,you want the .100 to move the tire out, this toe out condition allows the car to turn in right away, without the outside tire toeing out, the car will push as it cannot turn in as quickly as you want it to
Old 09-17-2006, 09:04 PM
I am starting a new sub frame built around the the stock camaro A arms & stock sway bar location. I am using 2 in round tube W/ frame rails narrowed so I can fit an 18X12.5 wheel on the front. and I want to run a rear steer rack. just wanted to know what rack unisteer used to play W/ fitment. If any body knows it would help. Thanks Scott.
Old 09-18-2006, 12:51 AM
ilovefirstgens's Avatar
ilovefirstgens ilovefirstgens is offline
Im confused...
So are you gonna flare the living hell out of those fenders and royally screw your scrub radius?
Or juist notch the hell out of the frame rails so that it will fit and be able to turn at least a little bit
So the question is how and why do you plan to do this? somehow i dont see the need for a 335 front tire but thats just me.
As for the unisteer rack ill let you know how it is tommarow!
Brian
'68 camaro
Old 09-18-2006, 05:56 AM
68RS350 68RS350 is offline
Originally Posted by Sparky67
If that were true, then why would DSE, 21st century street machine, and Art Morrison (taking over on Wayne Due rack) be making sub frames with rack & pinions. The quick ratio box is an easy install, so that is the only possible reason. If you don't fall the Unisteer rack and pinion directions correctly. Some people like to skip steps, then I heard you will have problems with the unit. Check over on P-T.com and do a search on Unisteer, then you will understand.
Jeff
Is Art Morrison gonna take over making Wayne Due like subframes?
Old 09-19-2006, 11:42 AM
Silver69Camaro Silver69Camaro is offline
No, our subframe will have nothing to do with Wayne Due. If that were the case, we would have just bought his jigs and started selling them already. Ours wont be available for about 8 weeks or so.
