Old 05-26-2015, 06:19 PM
Sonar Chief's Avatar
Question Shocks are here!
my chiropractor is gonna love me .... heading out to the gym and FedEX pulls up, what am I supposed to do?
Anyhow, Ron Sutton valved RT SA are here, there is a problem thou .... the lower mount on the rear is 5/8 shaft and there are no male alignment bushing to fit the shaft. Am I retarded? I got plenty of 1/2 alignment bushings thou ... and even w the 5/8 female on both sides the shoulder is still taller and the shock rattles when the bolt and washer are tightened ... got it?
Look at the pics and see if I'm backwards and comment PLEASE ...
Shocks are here!
I get it .... male and female fit together!
That's TWO 5/8 females on either side ....there still is shoulder there!
Top is good to go w 1/2" bolt thou ...
6 bags if the same parts!
I'd have to use 5/8 washers to take up the space .... not good!
There are no 5/8 males for the female.
Ok I know I'm not the only one using RT ... please help! RT is gonna call me back tomorrow when they open! Am I missing something?
Oh, I sent the Dirty Dingo Misfit mounts back ... now I have to cut up some headers!
Thanks for looking and helping!
Old 05-26-2015, 11:22 PM
Shocks are here!
The sleeves do not fit together. its 1/2 (what you can male) to 1/2 male top and 5/8 to 5/8 bottom. **
You have the right parts....The 1/2" ones go on top and the 5/8" go on the bottom. One 5/8" washer on eash side. So stud, washer, 5/8 spacer, shock, 5/8 spacer, washer then nut. Also real racers position the adjuster at the bottom.
Old 05-27-2015, 06:22 AM
I've seen guys not only install them upside-down --- I've seen it where they place the adjuster in what would be "toward the outside"... so that the adjuster is absolutely impossible to get to. LOL
Old 05-27-2015, 08:08 AM
Question Huh?
Vince .... I'm not a smart man, my picture 2 is what is installed on the top to take the bearing from 5/8 to 1/2 .... duhhhh, check image below!
The lower mount just change up the order? Install washer on the outside of the sandwich? I didn't know that's where they went, I just grabbed two washers.
Adjusters on the INSIDE bottom (Weld's comment) got it!
Now there is interference w the shock and the mount .... what's next? Longer shock stud to push the spring out away from the mount?
Thanks ...
Michael
Old 05-28-2015, 01:01 AM
Thanks ...
Michael
Check your piuion angle. The lower mount should be at 90 degrees with the pinion 2 degrees down.
Your a smart guy....you just took this literally didn't you.
Old 06-04-2015, 05:58 PM
LanceL LanceL is offline
Chief, do you have any pics of how the dash and cowl come together? On a nova they are welded, does the camaro do the same?
Old 06-04-2015, 08:53 PM
Smile
Vince ... I called RT and Josh sent me out the correct spacers for the lower shock mounts. I did read the directions, they were not that specific ... they were actually outdated considerably, offered to send new pics to update their instructions.
Lance ... the dash and the cowl panel are welded on the top. My front and rear AMD glass just came into town, figured I'd mock it up first before I welded them together. Same thing for the rear glass, trial fit before the quarters go on .... OCD!
WOW ... had a flash back looking for these pics, glad it doesn't look like that now!
Old 06-05-2015, 07:19 AM
paulk68 paulk68 is offline
How does the AMD glass look and fit are you happy with it?
