Old 06-15-2015, 10:37 PM
96z28ss's Avatar
96z28ss 96z28ss is offline
Default Wire Cover or Sleeve
Wire cover or looms or sleeves not sure what you call it.
Where can I get this stuff, Who makes it? Are other color combinations availiable?
1969 Camaro LS2/T56 D1SC
www.automotivedesigneng.com
Old 06-16-2015, 06:44 AM
Schwartz Perf Schwartz Perf is offline
Supporting Vendor
I haven't seen that exact stuff before.. but WireCare.com has a lot of sleeve products, most are made by TechFlex
-Dale
SchwartzPerformance
SchwartzPerformance.com
GMachineChassis.com
LSxEngines.com
Facebook | Instagram | YouTube
Old 06-16-2015, 06:47 AM
lsuguy's Avatar
lsuguy lsuguy is offline
I plan to use Techflex when I get around to wiring. If you look for Furry Letters store on ebay the guy sells just about every size/color by the foot.
Old 06-16-2015, 09:25 AM
I got some from here, but I have seen the exact one your showing, somewhere on line.
http://www.ebay.com/sch/furryletters...p2047675.l2562
Old 06-16-2015, 11:56 AM
Waytek has you covered if you want black
http://www.waytekwire.com/products/1...g/&pageSize=36
They also have heat shrink cable sleeves in black as well
http://www.waytekwire.com/products/1...bric-Sleeving/
Old 06-16-2015, 08:15 PM
no go nova's Avatar
no go nova no go nova is offline
Whats that paint on that block and trans?
Old 06-17-2015, 03:22 PM
96z28ss's Avatar
Is it wire inside a hose?
Old 06-18-2015, 07:01 AM
Supporting Vendor
It does look like AN hose more than anything. Could very well be I suppose....
-Dale
SchwartzPerformance
GMachineChassis.com
LSxEngines.com
Old 06-21-2015, 08:18 AM
69hugger's Avatar
69hugger 69hugger is offline
It IS hose. The OP picture is from the Angelo Vespi/ DSE Camaro. I had some of the same hose on my car (DSE worked on my car too). I shortened a piece of it...it is cloth braiding over a lightly convoluted inner plastic liner. Just cuts with a sharp scissor. In my case it has A/N style 2 piece fittings. It is easy to work with...much more than SS braided hose.
I like it with the shrink tube for cable cover. Slick...
This is a pic of the hose used for my fuel tank breather.
Summit has it with a blue or red tracer. Not sure where to get it with the gold tracer. I wonder if DSE would divulge?
I hope that helps.
Bill
Bill
'69 Camaro / 534 BBC / DSE Built
'67 C10 / LS-3 w/Magnuson / Roadster Shop Chassis (SOLD)
'71 Blazer / LT4 / 8L90 / Roadster Shop Chassis / Ride Tech Air Susp.
Old 06-21-2015, 12:21 PM
rallystyle rallystyle is offline
69hugger that hose in your pic is goodridge ptfe hose 910 i think.
96z28ss i think dse just pulled some of the covering from the goodridge hose to cover the wires to make it all match.
I use techflex for covering my harness and it looks good. dont think i would want it that close to my exhaust as it might melt. wirecare and amazon are good places to get tech flex from.
1970 El camino
1969 camaro
1996 civic
