Old 07-30-2015, 02:16 PM
RidiCat69 RidiCat69 is offline
Have an 03 cobra pedal assembly here, measured out to a 5:1 brake pedal ratio.
Like your build!! I have a 69 Cougar I'm doing a slow build on also.
Old 07-30-2015, 02:29 PM
1Bad68Cat 1Bad68Cat is offline
Thanks RidiCat69 for the info. Would you mind sending me the measurements you took. I want to eliminate any possible rounding errors when I calculate where my pivot point will need to be. I'm a little surprised, I was thinking it would have been closer to 4 than 5. Also, did you take your measurement from the center of the pivot to the center of the pedal pad or the bottom of the pedal pad? I've seen illustrations showing both. Thanks again.
Robert
Old 07-30-2015, 03:09 PM
No problem, Robert.
I retook measurements for both ways and you can decide which to use.
Center of pivot to center of pushrod lug is 2.75"
center of pivot to absolute bottom of pedal pad is 14.25".
this is what I got 5.1:1 ratio with.
Center of pivot to center of pedal pad is 12.75", giving a ratio of 4.63:1
Ryan
Old 07-30-2015, 03:11 PM
What pedal setup are you looking to use?
Old 07-30-2015, 03:16 PM
fleetus macmullitz's Avatar
Very interesting build.
Old 07-30-2015, 04:18 PM
Oh wow! Didnt know they were that low! The had an 04 Cobra as a daily for a few years, loved the hydroboost. Had good pedal feel without being over assisted. Did a 70 Mach build recently and used the stock pedal setup. Got a needle bearing setup for the stock clutch pivot rod. Don't know what you're doing in that area, but it's much smoother than the bushings if you haven't already done so.
Finally getting settled into my new digs, and trying to get back to mine. Only other cougar on here right now from a brief search. Keep the updates comin!
Ryan
Old 07-30-2015, 09:39 PM
Ryan
Yeah, I was a little shocked too when I took the measurements. My brother had an 04 Mach I and I loved the brakes on it too. I was fortunate to find a used 04 cobra hydroboost for cheap and decided I would adapt it to my car. As for the clutch setup, I did install the roller bearing conversion. I used a Scott Drake kit. I hope to get the new wedge soon so I can modify my pedal accordingly.
Robert
Old 07-30-2015, 03:18 PM
No problem, Robert.
Ryan
Thanks Ryan. I am using the power brake pedal for the 67 cougar. Right now the pin is lower than the hydroboost rod. I will move the pin and also likely the pivot so that the arc of the pedal matches the direction the hydroboost rod travels (currently it travels up at an angle because of the wedge). I believe the stock 67 ratio for power is around 3:1.
Robert
