Old 08-03-2015, 10:10 AM
dhutton dhutton is offline
Originally Posted by parsonsj View Post
Another (related) question: does anybody have a line on the voltage vs pressure map of the GM AC refrigerant sensor (AC Delco pn 15-51258)? I've been in contact with a vendor about a standalone fan controller for AC and engine coolant temp.
I've done some googling without much luck, though why I would expect anything other than bad luck is a good question.
I think the sensor map would be resistance in ohms versus pressure. I am guessing this is something you could measure with a little ingenuity, a tank of MIG gas, a regulator and an ohmmeter.
Old 08-03-2015, 10:42 AM
parsonsj parsonsj is offline
Sensor data, just pulled from the car:
John Parsons
Old 08-03-2015, 10:52 AM
It's a 3 wire sensor: 5V, ground, signal. So the ECU is measuring voltage. Internally, the mechanism is resistance, but that is translated to voltage for convenience.
John Parsons
Old 08-03-2015, 10:53 AM
Thanks for explaining it. I was puzzled a little. Pretty clever measuring it in the car.
Old 08-03-2015, 10:58 AM
Glad I'm rehabilitating my reputation after the cardboard in the intercooler fiasco.
John Parsons
