Old 08-06-2015, 06:45 AM
RLJ676's Avatar
RLJ676 RLJ676 is offline
The one call I had to make to the tech line was resolved quick and easy, just sucked having to wait till Monday as my Dad was in town working on the car for the weekend and wanted to see it completed haha.
Bret one suggestion I'd make is for the lower arms packing 2 different bushings, a "narrow" and a "wide" inner version. This would allow people who's tabs have come together significantly the option to run the narrower inner bushing to cut out hours of struggle in installing.
Old 08-17-2015, 11:47 AM
conester2013 conester2013 is offline
I also have the Ridetech level 2 installed in my 69 Camaro. I will agree that the lower control arms are tough to install! I ended up using a little oil on the frame to help slide them in....finally got them in after I almost lifted the car off the jack stands with me under it!! A little scary there! Ridetech really can't do much about the difference in the frames so I don't fault them on that.
I will agree though that their directions could be WAY better! If I wasn't as handy as I am, I might have had a lot of issues installing this suspension. I think they can do a LOT better job with the instructions to make it a little easier for the average joe.
Another issue I had, that I'm not sure others had, was when I went to install the front coil overs on the lower strong arm, the aluminum spacers they give you that go on each side of the coil over were too big to fit in between the strong arm center bars and I had to sand one spacer down until I could get it to fit. I took the other side to a machine shop and had them shave a couple thou off so they went in easier. Not sure why that was an issue, but I was a little disappointed I had to even do that.
As far as my powder coating, it has held up very well.....except for the time I got my tires balanced and the dumb @ss at the tire place put the jack UNDER the strong arm instead of the center of the sub frame.....that chipped my powder coating on both sides!! I was pissed!!
All that being said, I am VERY happy with the Ridetech suspension! This is my second year with it on my car and I hunt for curves all the time so I can enjoy how tight the car is and how well it rides!
I put mirrors in front and back of my car at every show so I can show off the suspension! Bret, any chance I can get some Ridetech stickers/decals that I could put on my lower strong arm to show that they are Ridetech's? They come on the uppers, but you can't see that. I'd love to spread the word for you guys at the shows!!
Brian
Old 08-17-2015, 12:09 PM
Erik Beckett Erik Beckett is offline
Brian, did you have any clearance issues between the outer tie rid and your rim or tire? I just got mine installed and having contact between the too. Josh is suppose to call me back but I have not heard from him yet. My kit did not i clude a spanner wrench either. So its just sitting there u til I can adjust the springs.
Thanks, Erik
Old 08-17-2015, 01:41 PM
paulk68 paulk68 is offline
I had to sand some of my spacers as well to get them to fit.
Old 08-19-2015, 07:36 AM
rodney@ridetech rodney@ridetech is offline
Was it tighter on the inside or outside? Was it the same on both sides? With the way the 1st Gen arm goes up into the frame, there is not a lot of wiggle room. We shoot for the center of the opening to minimize fitment issues, but the tolerances back then make it tough.
We are constantly trying to make them better. What additional information would you like to see in them? Sometimes it is hard for us to relay the information to the customer due to the fact that we know how it gets installed. I now take care of our instructions and would love to hear some input from our customers to make them better. You will not offend me, I want to make them better.
I noticed your arms are a couple of years old, we were running them right at the spacer width then. We changed that to 1/16" wider to help prevent having to modify the spacers, but yours would have been before the change
It does make them a joy to drive. We just bought another 2nd Gen, WOW it is scary with the stock suspension.
Brian
PM me your name and address and I will get some heading your way.
Old 08-21-2015, 08:14 AM
I think it was the same on the inside and outside. I tried prying the frame apart a little but I couldn't get it past the point where it just sprung back to where it was, so I just used brute force and my massive strength (haha) to get them in. Eventually got them, but like I said and you said, these old car frames were all over the place back then with tolerances so you can't possibly make something that fits easily in every car.
I'll take a look at the instructions again and make some notes so you have something from my point of view.
That's good to hear! Glad you guys are improving all the time....that deffinately would have made it easier! It was just a little frustrating when they wouldn't fit and both parts came from the same vendor. Glad this has been resolved! Nicely done!
On the way!
Thanks!
Brian
Old 08-22-2015, 08:50 AM
I've never seen better customer service, or caring for the overall quality and experience, than what I've seen on here from RideTech.
I think anyone thats going to write instructions - should invite a few total non-car people to install whatever it is they're trying to write about - and see where they don't understand - or need a better photo... The writer - having a complete understanding of what it is they're doing - doesn't "get" the confusion or the self doubt. You need a different set of eyeballs to help with this.
As a hot rodder --- I take the attitude that I WILL need to modify a part to make it fit correctly. There just are too many tolerances and variables to make every part fit every other part like a Swiss watch. That's an impossible goal.
Old 08-22-2015, 01:46 PM
rallystyle rallystyle is offline
gregweld i would say that is good input but i would also say that to put a install video on youtube or something would be a good idea. i would also let potential buyers know what they would be getting in to.
1970 El camino
1969 camaro
1996 civic
Old 08-19-2015, 07:41 AM
My email is [email protected] if you have problems on the weekend. Give me a little time to reply due to the fact that I might be in a poor service area or doing something that I can't reply right away, but I will get back with you.
