Old 08-09-2015, 05:43 PM
Swain's Avatar
Swain Swain is offline
Volts drop down to under 10 while cracking. Not sure what the problem is ahhh
Jason Swain
Build Link 68 Camaro
https://lateral-g.net/forums/showthread.php4?t=16865
Old 08-09-2015, 05:53 PM
cpd004's Avatar
cpd004 cpd004 is offline
I think that'd be fine to start it. Was VATS disabled?
Where are you measuring that voltage drop at?
1971 Firebird
2017 SS
Old 08-09-2015, 06:08 PM
Swain's Avatar
At the red wire that comes off the fuse box also another hot wire. I bought the harness from a forum member maybe they weren't deleted. I'll call PSI Monday
Jason Swain
Old 08-09-2015, 06:24 PM
dhutton dhutton is offline
VATS delete is in the tune, not the harness. If it is not deleted, it will start and run briefly.
Old 08-09-2015, 07:36 PM
Swain's Avatar
Sorry I meant ECU and Harness
Jason Swain
Old 08-11-2015, 05:56 AM
79 Camaro 79 Camaro is offline
If you hooked up the 12 volt switched to the original wire that runs to the coil and it was older style points ignition the coil wire will have a resistor built limiting voltage during run.
I've never heard of a brake light switch wired to the ECM when using a manual trans that would prevent it from starting. Only time I've seen it was to make the reverse lock out work like stock.
Try wiring the switched 12 volt to 12 volt constant just temporarily to see if it will fire. If it does disconnecting the wire will shut the computer down and shut off the engine.
From what I've read a bad cam sensor will not shut the engine down but a bad crank sensor will.
Old 08-11-2015, 08:16 AM
Swain's Avatar
I ran a constant hot wire still nothing. Fans come on right away I heard that means theres a code. Shipping the ECU out to PSI today. This will be the best thing to do as they can program it to my specs.
Jason Swain
