Old 08-11-2015, 09:06 AM
Swain's Avatar
Swain Swain is offline
Originally Posted by dhutton View Post
I recommend a low cost code scanner if you don't have one. Get one that lets you reset codes too. Very handy for these swaps.
I have a scanner it will no link to ECU.
Tried everything lol.
Jason Swain
Build Link 68 Camaro
https://lateral-g.net/forums/showthread.php4?t=16865
Old 08-11-2015, 09:08 AM
cpd004's Avatar
cpd004 cpd004 is offline
My scanner wouldn't link when a fuse blew on the PSi harness. Changed the fuse and everything worked.
1971 Firebird
2017 SS
Old 08-11-2015, 09:28 AM
Swain's Avatar
Checked all the fuses 5 times or more ha. I wish it was simple something so simple. Prolly is
Jason Swain
Old 08-11-2015, 09:35 AM
dhutton dhutton is offline
What about all your grounds? How is everything grounded?
Old 08-11-2015, 09:47 AM
cpd004's Avatar
Do you 'feel' the other relay click when you turn the key?
1971 Firebird
2017 SS
Old 08-11-2015, 11:35 AM
Swain's Avatar
I have grounds all over the place. I will see what PSI can come up with later this week. Hopefully it is my wiring or something easy. They will make sure the ECU is programmed to my specs.
Jason Swain
Old 08-11-2015, 12:06 PM
Heavy grounds from the battery to the block and body? Ground strap from the block to the body? ECM needs a nice clean ground.
Old 08-11-2015, 12:26 PM
Swain's Avatar
I have a heavy wire straight to the block. then Ground to the Subframe. I have sold mounts on the subframe.
Only thing it could be maybe I need a better clean ground to the body.
The ECU is grounded to the body.
Jason Swain
Old 08-11-2015, 09:20 AM
Damn, you at least get A for effort..
Old 08-11-2015, 01:00 PM
TomM's Avatar
TomM TomM is offline
This might be a clue......
You need to constant hot to the PCM, fused from the battery. The you need your keyed hot(which you have already verified). Once you plug in your scanner and turn the key, you should be able to connect to your PCM. If not, either the OBD connector is not wired correctly, or you don't have computer power, i.e., computer not booting up.
Your OBD connector should have a hot wire from the keyed hot and then a ground. The other wire goes to the PCM. You can check the pin with a volt meter once you turn the key on and see if there is power at the OBD connector.
That is what I would check first.
T,
