Old 09-09-2015, 10:29 PM
zj510's Avatar
zj510 zj510 is offline
looking good. which pan did you end up with?
I ended up with the f body pan great clearance to the crossmember and doesn't hang down past the crossmember
Old 09-10-2015, 09:48 PM
zj510's Avatar
I got the driver fender modified. I didn't like how the driver fender came down different then the passenger so I decided I wanted to make them look the same once I get everything together im going to make some close out panels so you don't see behind the fender here's how it looked before and after
The rear end should be done getting the gear set up this week so I should hopefully have a roller this weekend.
Old 09-13-2015, 05:58 PM
zj510's Avatar
Well I got the rearend back so I was able to get the car setup as a roller don't think I did to bad was a bare shell this morning and was a roller before lunch.
Old 09-13-2015, 06:54 PM
The parts look nice looks nice! You made quick work of it too.
Old 09-13-2015, 08:00 PM
glassman's Avatar
glassman glassman is offline
Very nice!!! Looks great.
What heads you doing?
Color?
Mike
Old 09-13-2015, 08:09 PM
car is coming out great!! huge contrast from what it was before you started.
nice 55 210 too
Old 09-13-2015, 09:03 PM
zj510's Avatar
Color?
A buddy is porting and polishing the heads and a valve job. Thinking in the greenish gold realm something like Ford ginger ale or Subaru wilderness green metallic
Old 09-13-2015, 09:04 PM
zj510's Avatar
nice 55 210 too
Thanks yea looks like a totally different car and its actually a Belair
Old 09-14-2015, 12:14 AM
syborg tt's Avatar
Wow your really cranking on this car and it looks really nice.
Marty-MJ
www.garagescene.net
marty-mj
Old 09-14-2015, 01:37 AM
Tokyo_Torquer Tokyo_Torquer is offline
Interesting build.. what size tires?
1973 RS Z28, 401ci Dart Little M with AFR 227 comp porting heads, Callies Magnum crank, Lunati Pro Mod Rods, JE blower pistons @ 7.8:1, Littlefield 6-71 with 14 lbs boost, Reed solid FT cam with 240/250 duration @ .050", .523/.542" lift and a 112 LSA, T&D 1.6 shaft rockers, Lemons 1.875-2.0" step headers
