Old 09-18-2015, 07:44 AM
dontlifttoshift's Avatar
Originally Posted by Musclerodz View Post
yes, its clean
Is it safe to assume that you removed the filter and test drove it?
I'm out of ideas.
Donny
Old 09-18-2015, 12:01 PM
Musclerodz's Avatar
I'm out of ideas.
Yeah, me too. That's why I am here asking. I am not going to have any hair left if I don't figure it out soon.
Mike Redpath
Musclerodz & Customz
facebook page
Old 09-18-2015, 01:26 PM
OLDFLM's Avatar
OLDFLM OLDFLM is offline
Did you try venting the tank above the tank and filler level?
Ty Ingle, USAF Retired
FREEDOMBIRD
Old 09-18-2015, 07:49 PM
booah booah is offline
Eliminate the losing the ignition, see if you can rig up a timing light so you know if the spark stops at the same time while driving.
When it stops, if you remove the float level bungs and give he car a shake, does fuel come out?
When the car stops, have you tried removing the air cleaner and watching to see if the accelerator pump squirts fuel in?
When it stops, does it sputter or stop?
is the ignition feed hooked up to the main feed circuit breaker? The ignition uses a resistor wire, is the ignition compatible?
Old 09-18-2015, 08:50 PM
Musclerodz's Avatar
Borrow a spark checker that taps a plug wire, not losing spark
I have checked bowl levels, sometimes its low, but never empty
Only driving it with no air cleaner, can't see or do anything with shaker installed, still squirting fuel when it shuts down.
when it stops, it acts likes its out of fuel, but I had a fuel pressure gauge tapped into it while driving never lost pressure.
all factory wiring, factory resistor wire, factory coil, which I have changed, even unhooked the factory rev limiter to see if it was shutting the car down.
Has factory carb spacer about 3/8" thick, which should eliminate boiling the fuel in the carb
Mike Redpath
facebook page
Old 09-19-2015, 11:15 AM
It has to be losing fuel or spark unless the exhaust is clogged? I've seen it on modern cars where the cats will close up. Muffler batting? If that's not it, I'd swap the carb. It may have an internal clog in the primary circuit. Also, you may see a spark, but is it strong enough to jump the gap and still on every cylinder? Have you checked the coils resistance?
Old 09-19-2015, 11:59 AM
Solid LT1 Solid LT1 is offline
Describe the motor problem a little better......a quick die off would probably be electrical related.......stumbling before die off would be fuel. If there is any backfire.....could get into things like weak valve springs.
Old 09-19-2015, 03:33 PM
Musclerodz's Avatar
I starting to think its the floats hanging up or needle and seat issue. Its a brand new Holley, and I have adjusted everything to where its properly adjusted and purrs like a kitten in the shop, but the last couple times I have drove it now, it shuts down right after I stand on it like it running out of fuel. Whats driving me nuts is not the consistent failure, its the inconsistent way it shuts down.
Just swapped the coil, no change.
Mike Redpath
facebook page
Old 09-18-2015, 08:42 PM
Musclerodz's Avatar
yep, did not fix it either.
Mike Redpath
facebook page
