09-24-2015, 05:30 AM
Cleaner signal and you can run 3x cam.
09-24-2015, 06:39 AM
You mean 4x? :-)
Andrew
09-24-2015, 06:47 AM
What is a Warren PCM...I've never heard of one? Who is doing the install and/or tuning?
T,
09-24-2015, 09:02 AM
It's one of Thompson Motorsports new turnkey setup that will come dyno'd, tuned, and broken in. I have a local shop that will handle the install.
http://www.thompsonmotorsports.net/p...roducts_id=250
T,
09-24-2015, 09:14 AM
Originally Posted by Nativefx
There are only a few engine builders that I would trust. I much prefer starting with a GM crate engine, and taking it from there. My suggestion to you is that you do the same. Pick your LS3...get the matching GM ECU package, and enjoy your car with a 50,000 mile engine warranty.
Andrew
09-24-2015, 10:05 AM
Hi Andrew, I appreciate your input and you have been a great help even earlier on when I was thinking about buying a used "refreshed" motor. Once I decided to go with a new motor I have been doing a lot of research and considering the GM crate motors and other options. In the end, I guess it's never "enough", so I wanted something a little more custom. If I was going to run a different cam, even a different GM cam, it would have voided any warranty which kind of tilted me towards a custom motor.
Thompson Motorsports seems to have a great reputation not only for the product they sell but also for taking care of any issues should they come up. This set-up comes with a 24 month unlimited mileage warranty, which Kyle was kind enough to work with me on. As I mentioned, I do have the option for DBW, which I believe he said would come with a GM E38PCM to go along with a a 58x reluctor. The harness is custom made, but i'm not sure who they are using but he did say it is farmed out.
Andrew
09-24-2015, 10:21 AM
The 24x is for 3 bolt and limits cam selection.
LS3 design is 58x reluctor so going 24x is a step backwards.
Dyno tuned on an engine stand and then dropped onto you car with a different intake and exhaust should have a retune. With a MAF over SD it is not as important.
09-24-2015, 10:39 AM
I've just seen too many people choose "custom" this "custom" that and in the end be unsatisfied because their car doesn't run right.  I know that it is tempting to get the biggest, baddest combination that you think you can afford, but in my experience, less can be more.
If you want a little extra power, choose the LS3/525 and the matching GM harness and ECU. That cam is gentle on valve train parts, sounds great, and has an excellent torque curve. You'll save a bunch of money, and have an engine that makes more power than the average person can handle.
Or...for that same (roughly) money as that "custom" LS3, I would do a LSA. Again, with the GM ECU and harness.
That's just my 2 cents on the subject.
Andrew
09-24-2015, 09:36 AM
Thanks for the link. It doesn't relate much as to what the harness and computer consist of at all, so it will be hard to give you an answer unless we know what you are specifically getting.
Reason being is there are many options.
I see they state it uses a MAF (Mass Airflow Sensor = no speed density) and IAT, so does that mean for both 24X and 58X, DBC or BDW?
If not, are they running Speed density on 24X and not on 58X.
Who made the harness?
Who made the computer if it's not OEM?
What about replacement parts, should you have a failure?
A lot of companies make very different applications, Some use what is know as MEFI, or Marine Electronic Fuel Injection, which eliminates the MAF and uses Speed Density.
Sounds to me like the 24X DBC setup may be the Speed density type, hence the "custom" "Warren" computer.
If it is speed density, and I am not saying it is, not every "tuner" can tune it. They better be reputable and proven and they need to know their s**t or they can toast a 15K motor setup real quick.....you should find this out for sure. This means if you need a tweak here and there, there are few who can effectively do this for you. Not the case with closed loop tuning...(MAF)
Then there is the MAF system, which is still good for big HP, but is a little more street and tuner friendly for around town driving...
So you see, there are a lot of options, depends on what you are going to do with the car.....as to what is actually "better"...
Forged is good, but do you really need it? Is this just an around town car with occasional romp on the gas or a big smokey burnout?
T,
09-24-2015, 10:29 AM
Hi Tom, thanks for providing some input. Hopefully i can answer some questions and also make note of questions I should ask Kyle at Thompson.
As I mentioned above, if I decide to go with DBW, it will come with a custom built harness but I don't know for sure who they use. If I remember correctly it would utilize a GM E38 PCM with a 58x reluctor.
The drive by cable option would utilize the 24x Warren PCM and set up with a cable operated TB. The harness would also be custom made for this application.
As for the information listed in the link, I believe this was the options for the BDW setup using MAF and IAT. I'm not sure whether speed density would be the option with the drive by cable 24x setup, I would have to ask.
Forged may not be completely necessary, but they are running a special on their turnkey packages for the first setup of the 10 options they have. I was able to get the FI LS3 option at the discounted price. For the power level I was hoping to achieve, it made more sense to at least look at going to forged pistons, which is where my initial conversation started with them. It will mainly be street driven but at some point I hope I can do some autox and maybe large track.
Just for background, I took my car to bare metal to start my build and it includes RideTech Level 2 AirRide suspension with TruTurn and Musclebars, Baer Tracker full floater rear end on a 9" with 3.89 gears and TruTrac posi, Baer 6P brakes front and rear and Forgeline 19 x 11.5 (335/30/19) rear and 18 x 9.5 (265/35/18) front. The trans will be switched out to a T56 Magnum close ratio to go with the motor.
Let me know if there is anything else I should be asking or if you have any further input. I really appreciate anyone willing to take the time to share knowledge, even if they may have different views. Its great learning experience!
thanks, Jake
T,
| Thread Tools |
| Display Modes |
Hybrid Mode
