Old 10-07-2015, 02:08 PM
RussMurco's Avatar
RussMurco RussMurco is offline
The data is kind of interesting that you can clearly see the max Lat numbers on the Rival S are up about 0.08 to 0.10 G in LH and RH turns. Because it was cold and Waterford is small the acceleration and Decel delta does not show up.
I know once I get the Rival S on a bigger track where I can get some heat in them they will really work well.
Mark
Informative as always, Mark! Thanks for sharing and I always learn something interesting "looking over your shoulder" with your projects!
Russ "Murco" Murray
http://i1339.photobucket.com/albums/...psc7bc7b5c.jpg
"Liquidating excess cash through the automotive hobby!"
Old 10-07-2015, 02:16 PM
Stielow's Avatar
Stielow Stielow is offline
In full disclosure right now I have Bridgestone RE-71s 275 on the front and Rivel S 335 on the rear. The car feels very balanced. I finally got the 275 Rival S yesterday so I'll run those this weekend.
Mark
Old 10-07-2015, 05:55 PM
any chance of you telling us what your "next" project is .... another f body or are you going to jump to something else again ,possibly another chevelle ?
Old 10-07-2015, 07:23 PM
randy randy is offline
Any chance you can tell me what oil to break in my crate ls3 480hp?
Also what fluid are you using on your t56 magnums?
On the ford 9" what fluids are you using? weight, synthetic, non syn, brand etc? Any break in diff fluid either?
Old 10-07-2015, 07:44 PM
Build-It-Break-it's Avatar
Any chance you can tell me what temp to set my barbecue grill at to cook my turkey burgers?
Also what vitamins do you take before each race?
In your cereal what milk do you use? 2 percent? Whole milk? Almond milk? Any chopped up banana with it?
Thanks in advance,
Love Ahmad
Ahmad B
Old 10-07-2015, 08:47 PM
andrewb70's Avatar
andrewb70 andrewb70 is online now
Thanks in advance,
Love Ahmad
Andrew
Old 10-08-2015, 07:39 AM
Stielow's Avatar
I can tell you it is not a Chevelle.... The next project will be a 1st Gen but after that we have had a lot of talk about what to do next.
It has run the gambit of C-6 ZR-1 to 32 Ford to AWD Porsche to a Pantera....
We are really looking at power to weight, CG and areo. A lot will depend on what OUSCI does with rules and if I still want to play in that space.
I have been in some sort of build for 10 years and I might take a break. I have some big projects at GM that are going to pull a lot of my spare time.
We have a lot of great cars that are turn key track cars.... Maybe I'll just buy one of those.... then tune it up.
Mark
Old 10-08-2015, 07:46 AM
Stielow's Avatar
On the ford 9" what fluids are you using? Weight, synthetic, non syn, brand etc? Any break in diff fluid either?
Thomson breaks my engines in on normal engine oil (Like 2W30 Valvoline) then I run them on Redline 10W40.
I run D4 Redline oil in my trans
I run 90W120 normal oil in my diffs like Valvoline of similar with a big diff cooler. Keep it cool and the non-synthetic work great and are quiet. On a side note, I have had C&R build and dyno my last two diff. It is great. They are set up correctly, they are quiet and do not require break in. I have tried synthetics and they have always been noisy.
Mark
Old 10-08-2015, 07:51 AM
Stielow's Avatar
Thanks in advance,
Love Ahmad
I grill stuff at medium heat or until crispy on the outside.
Flinstone chewables vitamans.
2 percent with blue berries.
Old 10-08-2015, 08:18 AM
sebtarta sebtarta is offline
Mark
Best info ever! Time to change my rear diff fluid.
I knew I had the heat wrong, thank you once again.
