Old 10-14-2015, 08:21 PM
awr68's Avatar
awr68 awr68 is offline
Nice Fab/Body work!
Tony
'68 Camaro
Old 10-15-2015, 04:21 PM
Wow what a differance already. Nice job.
Old 10-16-2015, 07:16 AM
GPR's Avatar
GPR GPR is offline
We had a few rust holes in the floor that were cut out and new metal added.
Floor was sanded and epoxy primed black
Because this has a T-top we are going to add subframe connectors and a roll bar from S&W. The roll bar was sanded and epoxy primed.
Rusty Gillis
Gillis Performance Restorations
Port Richey Fl
www.gillisrestorations.com
Old 10-16-2015, 07:26 AM
GPR's Avatar
GPR GPR is offline
The major bodywork is finished
Two coats of SPI epoxy
Block sanded and a little more bodywork
More epoxy
I block sanded again and sprayed white epoxy. I have decided on a color SPI Orange. It is a little darker in person
Rusty Gillis
Port Richey Fl
Old 10-16-2015, 09:36 AM
Nice color choice, Rusty! Good luck with the build.
Old 10-16-2015, 10:38 AM
GPR's Avatar
GPR GPR is offline
The fenders have been sprayed white epoxy almost ready for SPI orange paint then I decided to fill in the marker lights
Ready for more primer. The wheels are off of Brian's 94 but the offset is wrong and the front cap won't go over the spindle
I sprayed two coats of SPI epoxy primer on the body and roll bar
I finished the bodywork and sprayed a coat of epoxy to seal it before spraying urethane primer
Two coats of SPI Turbo primer
The body has been block sanded and I sprayed a couple more coats of SPI Turbo urethane primer.
Rusty Gillis
Port Richey Fl
Old 10-16-2015, 10:45 AM
GPR's Avatar
GPR GPR is offline
The wheels and tires are will be using
Rusty Gillis
Port Richey Fl
