Old 10-18-2015, 05:53 AM
Default Pros and cons running fueline
Hi few questions
Any pros and cons of running the fuel line in the trans tunnel ? My tunnel is raised
Also anyone have PTFE hose brand advice? Anything to consider?
Old 10-18-2015, 06:24 AM
dhutton dhutton is offline
Originally Posted by XLexusTech View Post
Hi few questions
I would not do it. Heat from the transmission combined with risk of a broken driveshaft rupturing the fuel line.
Old 10-18-2015, 06:34 AM
I was thinking about both of those I was thinking it would be cooler then near the headers
Old 10-18-2015, 06:46 AM
The outside of the frame rail avoids header heat. Same as factory.
Old 10-18-2015, 09:29 AM
Fuel line in my Mustang was run in the trans tunnel -- couldn't get it moved fast enough!
Old 10-18-2015, 09:12 PM
randy randy is offline
why? use the stock line and route it. pretty simple to do
Old 12-17-2015, 05:37 AM
67ragtp 67ragtp is offline
Brown and Miller racing solutions. Convoluted PTFE liner, all crimped ends extremely high pressure check.
They currently have almost every cup team.
Great to work with, send them garden hose as templates or hose of your choice, indicate ends you want they will make them up, you can have heat insulation material covering certain sections near headers just indicate on template. Plug and play.
Great product, sleep at night, it will not fail! 4 bar no problem.
Rich
