10-20-2015, 07:50 PM
LS Engine Idling Issue
Finally got my car started (after 8 years of building) but it won't idle at all. I have to feather the pedal to keep it running. Also noticed my volt meter on my New Vintage gauges is only showing 8 volts when running. Fan 1 comes on in the key on position. Let's start with the idling issue first though. I do know hat PSI programmed my ECM for the wrong style MAF. Would that be causing the issue? I talked to Gary at PSI this morning and he said the car would still run like it is.
2008 6.0L short block
LS3 heads
LS3 Intake
Custom cam/springs
Stock valve train
Ok, where do I start with the idling issue?
10-20-2015, 08:30 PM
Check the port on the drivers side of the intake just behind TB. Should be plugged
10-21-2015, 04:14 AM
It's capped.
10-21-2015, 04:15 AM
How does the voltage play into this? Or does it make that big of a difference?
10-21-2015, 06:18 AM
I would 1st look for vacuum leaks and open ports on the intake. Ports on the rear for the booster etc. also check that TB and O ring are snug.
Is the MAF sensor installed?
What have you done regarding tuning for you set up?
10-21-2015, 09:39 AM
I checked all the vacuum/PCV hoses and they're all tight. I'll check the TBthis evening. Yes, MAF is installed. PSI did a start up tune when I purchased the ECM.
10-21-2015, 09:46 AM
I need to get a fuel pressure gauge installed. I'm sure there's probably some air in the fuel system as well.
10-21-2015, 11:45 AM
The 8 volt thing is a problem. Where did you pick up the wire to the gauge? Is your alternator charging when it is running? What is your battery voltage running and static?
These engines use a lot of power to run everything, it might just be this simple...
T,
10-21-2015, 01:13 PM
T,
I need to check it this evening to see if it's charging or not.
10-21-2015, 01:34 PM
T,
I tied it into the pink 12V wire from the instrument cluster wiring.
Thread Tools |
Display Modes |
Linear Mode
