Old 10-27-2015, 04:39 PM
Che70velle's Avatar
Tell us more! What's the overall plan for this car?
...are those bullet holes in the drivers door?
Thanks Dad!!
Old 10-28-2015, 01:41 AM
Blackened Blackened is offline
Thumbs up
Sweet love to see some black Firebirds. Too bad you couldn't encase one of those black widows in some sort of resin and CNC a shifter ball out of it...
Are you going to put a 69 TA hood on it?
Old 10-28-2015, 07:43 AM
AtomicFirebird's Avatar
AtomicFirebird AtomicFirebird is offline
Wow, that's a cool idea!
Old 10-28-2015, 03:18 PM
MetalWorksClassics's Avatar
MetalWorksClassics MetalWorksClassics is offline
Default Black Widow
Ha ha...no bullet holes...drilled holes from a previous attempt at pulling a dent out of the door...we will be re-skinning the doors.
The plan for the 68 is a Pro-Touring car, it will be running a Butler Performance engine backed by a TREMEC T-56 six speed tranny with a Centerforce DYAD dual clutch, all Ridetech suspension, Forgeline wheels tucked inside Detroit Speed mini-tubs, and big 14" Wilwood brakes on all 4 corners...should be a really fun build, and a great performing car.
Old 10-28-2015, 03:22 PM
Default Acid dipping
The first thing we did was send the 68 off to our acid dipping facility to get us to ground zero before starting the metal work.
Old 10-28-2015, 09:07 PM
T_Raven's Avatar
T_Raven T_Raven is offline
Subscribing. Can't wait to see what you do with it.
67, 68, 69 & 72 Firebirds, 79 TA, 89 GTA, 01 WS6, 68 Camaro, 68 Mustang, 54 GMC awd turbo, 67 GMC
Old 10-29-2015, 07:09 AM
HotRod68Camaro's Avatar
HotRod68Camaro HotRod68Camaro is offline
I'm going to be following this one.
Kyle
Old 10-29-2015, 11:17 AM
Default Removal of damaged panels
The 68's main body shell had a great deal of damage...everything from dents, to rust, to poor attempts at bodywork by previous individuals. So we got busy removing panels...when we were done, the passenger rear quarter was about all that remained for external sheet metal...Here is day 1 of removal.
Old 10-30-2015, 11:03 AM
Default More sheet metal removal
Here is after day 2 of sheet metal removal...we also melted out the factory lead, and removed the inner wheel tubs as we intend to install Detroit Speed mini-tubs.
