Old 11-03-2015, 12:57 PM
samckitt's Avatar
samckitt samckitt is offline
Originally Posted by Old66Tiger View Post
Thanks. What year and models does this fall into? Or is this pretty much the same across multiple models?
I can't say 100%, but I pulled mine off of early 2000 front wheel drive cars. I pulled a few for friends & they all worked. I bought the connector from EFI Connection & it was the same connector as what I found in the junkyard. I assumed/hoped that it was the same sensor. I think I paid $5 a piece for the connector pigtail, sensor, & segment of hose.
I haven't done it on my AC line yet, but buddy took one of these to AC shop & they removed the fitting from the tube & then braised to an elbow that then gets crimped onto a hose.
Scot
86 Monte SS
LS2/T56 Magnum
Old 11-04-2015, 08:48 PM
andrewb70's Avatar
This looks about right:
http://www.rockauto.com/catalog/more...nid=516&jpid=0
Andrew
Old 11-05-2015, 05:23 AM
samckitt's Avatar
EFI Connection has the AC sensor pigtail & parts:
Pigtail:
https://www.eficonnection.com/eficon...spx?ItemId=910
Connector parts:
https://www.eficonnection.com/eficon...spx?ItemId=207
And sensor:
https://www.eficonnection.com/eficon...px?ItemId=1080
Sensor through them is $60, pigtail is $11.50.
Info on the page for the sensor states:
" We currently do not know where to source a fitting."
That's why I headed to the junk yard. I think I paid around $5 a piece for the fitting, sensor & pigtail.
Scot
86 Monte SS
LS2/T56 Magnum
Old 11-05-2015, 09:33 AM
Obsin71Ls1 Obsin71Ls1 is offline
You don't need to go to the junkyard to get the fitting for the A/C pressure switch; it is available from several vendors either in aluminum or steel. I don't know if I can post non-sponsor links here but if so, let me know and I'll provide the links. Also, as far as I know, GM A/C pressure sensor used in most LS cars has a fine metric thread. Specifically M10 x 1.25.
The fitting is on the right.
Old 11-05-2015, 10:01 AM
samckitt's Avatar
That doesn't look like the threads on fittings for the sensors I have. The ones I have are a finer thread I believe. I will try to find one in my shed (moved & stuff is everywhere), and take a pic of it.
Scot
86 Monte SS
LS2/T56 Magnum
Old 11-06-2015, 02:18 PM
dontlifttoshift's Avatar
So I just came across this gem on a bmw forum.
Of particular note are sensors number MT1297 and MT1339. They use the same connector and have nearly the same voltage readings but one is female 3/8-24.....same as a female Vintage Air trinary switch. VA has adapters to install that into a drier or inline fitting if you want.
MT1297 transfers to a GM 22599559 or ACDelco 15-72104 and it seems to have the same pressure/voltage ramp as the one parsons outlined about 4 pages back.
****Edit**** ACdelco 15-72104 does not fit the Vintage Air adapters. Thread and pitch are wrong so that is out.....back to the previous plan.
Donny
Old 11-11-2015, 10:42 AM
Old66Tiger Old66Tiger is offline
That's cool. I sent an email VA asking about an adapter and no response. The only fitting I see that would work is a Schrader style but not sure if that is what you are referring to.
Old 02-04-2016, 05:59 AM
For what it's worth, a Vendor sells something that would make this slightly easier possibly.
http://www.restomodair.com/shopproducts/t-fitting/
I think that's the route I'll be going.
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
The Following User Says Thank You to will69camaro For This Useful Post:
colorado80439 (12-21-2020)
