Old 11-12-2015, 06:57 AM
Evan Iroc-Z Evan Iroc-Z is offline
No problem. Glad I pointed it out, that's a good looking car you have.
'89 IROC-Z Turbo 3.8 5SPD
LS1 Brakes|Wilwood Prop Valve|LS1 Master Cylinder|Aluminum Driveshaft|LS1 3.42 Rearend|Adj PHB|Adj LCA|LCARB|Koni Struts|Koni Shocks|Adj Caster/Camber Plates|STB|10 Spoke SS Wheels|PHB Relo Kit|Adj TA|SFC|ARAP Based Prom|B&M Short Shifter|Underdrive Pullies|SMOG!|AIR!|Rag Joint!|Magnaflow|Ported Plenum|Misc Stuff
Old 11-12-2015, 06:14 PM
64mali's Avatar
64mali 64mali is offline
So is started the ol T56 swap. I wanted to try and keep the floor as original looking as I could on the top and bottom so I opted to section and raise the existing tunnel. Here's kinda how I did it
Old 11-12-2015, 06:20 PM
64mali's Avatar
Old 11-12-2015, 06:34 PM
64mali's Avatar
I created roughly 2" strips using the cuts as a template then tacked them in place. I rolled the floor slightly in some spots and tacked it all together essentially raising the trans 2"
Old 11-12-2015, 06:46 PM
64mali's Avatar
Then I had to relief cut the firewall and bring it up to the height of the tunnel. The end of the tunnel needed some work molding the old pieces and new pieces together
Old 11-12-2015, 06:59 PM
64mali's Avatar
I cleaned it all up and put a coat of primer before I welded up all the old holes in the floors. I welded in bucket seat brackets and prepped the floors for Por15. The florrs were all in all pretty clean. There was surface rust in all the standard spots but nothing went threw and they were all in all pretty solid
Old 11-12-2015, 07:04 PM
64mali's Avatar
Meanwhile, underneath I welded in the Chris Alston trans cross member and boxed the frame rails. The hardest part of the rails was straightening all the years of jacks and jack stands bending the old frame rails, especially with the body on the car.
