Old 11-13-2015, 12:38 PM
Blake Foster's Avatar
Originally Posted by Dipped View Post
I was in the same boat a couple years back. If I could do it over again I'd have gone with a Roadster Shop or possibly Ridetech/Speedtech. I regretfully took a friends recommendation and went with Chassisworks. They produce a decent product however god forbid you have an after sale issue. Two words, High & Dry. The Roadster Shop suspensions look phenomenal. RideTech and Speedteck are less expensive while still providing a great performing system.
Speedtechs NEW Extreme Subframe has the best Suspension Geometry on the market. the most adjustability, the most shock options, the Best Spindle you can buy. and right now our introductory price is the most affordable on the market. (call us CRAZY) package it with our Torque arm rear suspension which is the EASIEST to install and set up. and you have a GREAT set up.
http://www.speedtechperformance.com/...cat/cat160.htm
Blake Foster
Old 11-13-2015, 05:50 PM
Dipped's Avatar
Dipped Dipped is offline
Wow That sounds pretty impressive! If I could uninstall my Chassisworks system and replace it with the above I would. I'll definitely take the speedtech system under serious consideration once I break ground on my 68 Camaro.
1968 Firebird
lS3/T56/9"/24 Pistons/Forgeline VX1s/Faulty "Ride Height Too Low" Shocks
Old 11-13-2015, 10:08 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
IMO, there are almost too many suspension choices on the market today. We cannot tell you which is best for you because only you know what you want. The only advice I can offer is that you read about all the different suspensions from the different manufacturers. I will say that as long as you stick with one of the forum sponsors you will be much better off.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
