Old 11-20-2015, 02:00 PM
gnx7's Avatar
gnx7 gnx7 is offline
I need to put some front brakes on my Chevelle. Already have the disc/parking brake drum combo from Wilwood out back 12.19".
Is the cost of going to a 14" front brake worth it? I'm guessing the car will be around 3800lbs.... hopefully less. Alum turbo'd 5.3, T56 Magnum, 50lb twin disc clutch, heavy 9", full cromo cage, heavy CTSv power seats, a/c and p/s with 25 gallon s/s fuel tank. I have the ATS front spindles with ZR1 hubs on it.
Looking at Wilwood 6 piston 14" fronts.... are the C6 Z06 vette brakes cheaper and just as effective?
