Old 11-25-2015, 12:49 PM
Sonar Chief's Avatar
Question
That's quite a lot of work to resurrect this 68!
Question: how do you plan on keeping the rust from starting again? Seems from the pics that you guys are putting on the panels without etching primer ... is there a coating on the car now?
Just curious ... love the pics!
Michael
Old 11-25-2015, 03:22 PM
preston preston is offline
Along similar lines....
When you spot weld two panels together, the top side I can see is usually bare. Is the backside bare or do you have weld thru primer on it or do you leave the EDP coating on it ? and the 2nd panel below it, same question, is it bare, EDP, weld thru primer - Do you leave a coating on the back panel and then just scratch/drill it away through the welding hole ?
Love to see the skeleton dressed and looking good, I know from experience though what the photos don't show are hours of lining up panels in 3 dimensions.
Old 11-25-2015, 04:23 PM
MetalWorksClassics's Avatar
MetalWorksClassics MetalWorksClassics is offline
Michael
Everything will get epoxy primed and seam sealed once the panels are in place, so no moisture will get in.
Glad you are enjoying the pics!!
Old 11-25-2015, 04:39 PM
Michael
I saw this same thing... Not going to argue the point, but I always used weld thru primer on everything before putting stuff back together. Bare metal WILL rust. I don't care whether it gets wet - there's moisture in the air.
Old 11-25-2015, 04:52 PM
Default Rain gutter removal
We removed the drip rails for a smooth and modern look.
Old 11-25-2015, 05:15 PM
AtomicFirebird's Avatar
AtomicFirebird AtomicFirebird is offline
Keep them coming, Please
Old 11-25-2015, 08:51 PM
Cool
There is many more on their website ...
Old 11-30-2015, 01:37 PM
Thanks guys...yeah, if you want to check out more of our projects in the works, here is our website: http://www.metalworksclassics.com/
Thanks!!!
Old 12-01-2015, 03:12 PM
Default Door gaps
Next we built up the rear quarters to get a nice door gap.
