Old 12-06-2015, 08:40 AM
fleet's Avatar
fleet fleet is offline
First off, thank you for your service.
Cool project and a good looking Alfa for sure...my son's fav.
Subscribed.
Old 12-08-2015, 05:23 AM
Catdaddy60 Catdaddy60 is offline
Default I aplaud your choice
Having spent a few years and tears in and on ALFAs I have some pointers If you would like. The body is a fun worthwhile project pay particular attention to the lower side panels as these are structural and have a tendency to rust. The rust you show is pretty common and while fixable is a pain. The suspension can be enhanced by adjustable upper control arms in front for camber and spacing the spring perches on the lower spring plates be VERY careful with the front springs they are preloaded very heavy and will hurt you if you do not respect them. the rear suspension can be helped with the usual bushings and shocks but if you really want to go all out look for the GTA "sliding block" suspensions on Auto Delta cars of that vintage. The Transmissions are good and solid. The engine, the "2 liter" has some issues in the head that you will spend a lot of money and effort trying to correct the port flow and frankly you are better off seeing if a newer ALFA will bolt up ALFA uses a ECOTECH engine that was used in the Cavalier Colbalt that is a better engine has more HP potential and is more reliable I'm not sure which model ALFAs used it but it is a better option. having said that if you do choose the 2000 one of the things to pay attention to is the head gasket. The manual states to torque to some thing like 40 lbs the in 5 lbs increments to 60 or 65 lbs to make the Gasket live longer torque to the initial setting then go 5 lbs for a couple of round the 2 lbs to to the end torque setting. This helps the head stay in one plane and even. It DOES make a difference. Good luck with your car and yes thank you for serving.
Old 12-17-2015, 11:55 AM
bulletpruf bulletpruf is offline
Thanks for the detailed input. It's much appreciated.
1972 Alfa Romeo GT, Track Day Project
1971 Javelin Road Race Project, owner built 401, T-10
1968 GTO Convt, owner built 455 and TH400
1966 Fairlane GT Convt, 428 CJ, owner built toploader 4 sp
Crazy week here. Got back from Bosnia (Sarajevo) on Wednesday, only to find out that I had to leave for Ethiopia on Thursday. However, after my flight from Naples to Frankfurt, I was called back to the mother ship; trip canceled. Painful trying to get back to Naples – I flew from Frankfurt to Munich to catch a connecting flight to Naples, but the flight to Naples was canceled. So I spent the night in Munich. Next day, I flew back to Frankfurt and caught a flight to Naples.
So instead of a weekend spent in Ethiopia, I was home and able to get a bit of work done. Can’t really tell by looking at the car, but I was fairly productive –
-Got the brake booster/master cylinder out, along with the clutch master cylinder.
-Got the brake and clutch pedals out, and made up a few new curse words in the process.
-Front wiring harness is almost out.
-Intake manifold off.
-Exhaust manifold/exhaust off. I loves me some Kroil – this stuff is great for loosening up stuck/rusted bolts.
-Water pump off.
-Shifter out.
-One crossmember out – this one appears to be mainly for the driveshaft. Still have to get the transmission crossmember off.
-Front bumper off.
-Inner fender covers out – had to drill out about 5 rivets on each side. Was quite pleased to see how nice the sheetmetal looked behind the covers. The actual covers are in good shape, too.
Headed to Berlin for a few days of vacation this weekend. Should be able to spend some time on it in the next few weeks. Plan was to have disassembly complete by 1 January, and I don’t know if that’s going to happen.
Next step will be to pull the engine and trans. Had planned to drop the bellhousing and trans out the bottom, but that’s before I decided to fab up a wooden gantry to hang a chain hoist from. Now I may pull them as a unit.
Old 12-17-2015, 01:32 PM
Dr G's Avatar
Dr G Dr G is offline
Love these cars. As a lad I lived in the South of France from 1970-1973 and remember seeing these cars ripping around, along with Alpine-Renault's and the like.
Old 02-01-2016, 11:58 AM
Cool story. Don't see hardly any of these ripping around these days. I don't think I've ever seen one on the road besides mine, and I've been living in Italy for almost 8 months.
Frankly, not much vintage iron still on the road here.
Ciao,
Doors are off. Was able to do this myself since they're pretty light. Doors themselves are in very nice condition; no rust or repairs evident.
All the suspension is off but the majority of it needs to be cleaned and inspected.
Took off the panels at the rear of the front wheel wells. One is in need of repair. Can't believe how much dirt was behind them. Found an old rusty wrench back there, too. Given the amount of crud back there, surprised that this area did not rot significantly. Having said that, there is some rust on the driver's side at the front of the rocker that will need some attention.
Trunk lid is off. It's pretty rough.
Spare tire well has some rot that will need to be fixed.
Area under the windshield wiper transmission will need some work. Not going to be easy forming new metal to replace what's rotted.
Tried to do a bit of paint removal by scraping with a razor blade. It was easy enough to get the paint off but not the tan primer. Under the primer is a coat of bondo - pretty thick in places.
Interior is all out, of course. Front floor pans will need some patching.
Engine compartment needs a good cleaning before I start with the paint removal.
