Old 12-09-2015, 01:25 PM
I think you will have a hard time making it fit. The space between the drop in the center (where the dash sticks out) and the bottom is too short for the holley screen. I'm sure if you're willing it can be modified but it will be a tight fit.
I am looking at putting a racepak IQ3s in my car and it was a TIGHT fit and it's over 1/2" shorter.
This is my DSE dash with the IQ3 set in the position it would be installed and as you can see it's very tight fit.
The racepak dimensions are a good bit smaller than the holley in height.
Holley is 4.625" tall and 7.5" wide. Width should be no issue, but height will be the difficulty.
William
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 12-09-2015, 01:39 PM
Another example of an option and showing the space limitations is Hellfire's dash.
That display is a tight fit and it measures 4" tall x 6" wide.
Texas A&M BSME 2008
1992 Corvette ZR-1
Old 12-09-2015, 04:03 PM
rons69camaro rons69camaro is offline
Thanks guys! It looks like the Holley option is out due to size. Shoot me some pics if you get the racepak installed!
Old 12-09-2015, 06:59 PM
Will do. Waiting on iq3s to come out so I can have a fuel gauge integrated.
Hope to have dash ready in a couple months.
William
Texas A&M BSME 2008
1992 Corvette ZR-1
Old 12-09-2015, 08:58 PM
rallystyle rallystyle is offline
check post 10
https://lateral-g.net/forums/showthread.php4?t=51621
looks like they used the holley dash.
1970 El camino
1969 camaro
1996 civic
Old 12-10-2015, 04:02 AM
Yep. They definitely did. As said you could make it work. Just have to remove the "drop." You could modify the DSE label like some have and run a Nova dash pad and I'm sure make it fit.
That's what I wanted to do originally but it takes a little more work than I wanted to get involved with to make those modifications.
One thing I wish the holley dash allowed for is tuning. As of right now you can't make tuning adjustments with the Holley dash. Just the handheld or a PC.
Texas A&M BSME 2008
1992 Corvette ZR-1
