Old 12-10-2015, 11:00 AM
Sales@Dutchboys's Avatar
I recessed a Holley dash into my DSE 69 dash insert. By far the best dash on the market!
Ill add some more pictures later tonight.
dutchboyshotrods.com
269-823-2967
Old 12-10-2015, 12:47 PM
rons69camaro rons69camaro is offline
Dutchboy that looks amazing! What modifications did you have to make to the DSE 69 insert to make the fit? What dash pad did you use?
Old 12-10-2015, 01:02 PM
I searched all over and couldn't find what I am looking for. Does anyone know what the pro/cons are for the Racepak over the Holley dash?
Old 12-10-2015, 01:31 PM
Not sure pro's and cons but I'm curious what is under the extension on the 69 dash pad where he obviously removed it. Looks really good though!
William
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 12-10-2015, 02:12 PM
snappytravis's Avatar
snappytravis snappytravis is offline
I went with the holley for the fact it is pretty much plug and play setup. Because I am running the holley hp ecu. However after I purchased it, You may be able to run a Racepak through the holley ecu can adapter plug in. I never researched it any further. Holley has another extension harness that plugs in to the back of the holley digital dash. For turn signal and high beam and a few other inputs. I think the street version of the racepak dash may have this already configured. Something to think about. I didn't think that far ahead.. . This extension harness won't be available until first quarter of 2016,, I called holley on this.. so I guess I will be waiting..
Old 12-10-2015, 03:29 PM
Wait you cant run the Holley dash cause no extension harness?
I have all the harnesses for the racepak ready to go. Probably going with the IQ3s as it has easier use of the fuel level. I dont care for the turn signals so I'll likely run a panel from NVU for the signals and check engine/etc.
William
Texas A&M BSME 2008
1992 Corvette ZR-1
Old 12-11-2015, 04:52 AM
69hugger's Avatar
69hugger 69hugger is offline
FWIW, Autometer showed at SEMA a new display (called the SD7) supposedly coming in March or April.
Numerous screen options, configurable for any gauge combinations you want, warning lights & alarms, etc. Also has CAN connectivity,etc, etc.
Here's a few crappy cell phone pictures I took of the various screen options on their display. Sorry for the blurry shots...
At 4-5/8" x 7-7/8", it is almost identical in size to the Holley display. To fit it to the DSE dash insert, the drop down will have to be removed or at least notched out. I like the idea of recessing it like Paul did on his Camaro.
Bill
Bill
'69 Camaro / 534 BBC / DSE Built
'67 C10 / LS-3 w/Magnuson / Roadster Shop Chassis (SOLD)
'71 Blazer / LT4 / 8L90 / Roadster Shop Chassis / Ride Tech Air Susp.
Old 12-11-2015, 05:55 AM
Dave95z28 Dave95z28 is offline
Hopefully the Autometer Street Dash will be much cheaper than the data-logging Competition Dash which is around $4500.
Dave
Old 01-04-2022, 04:37 PM
camaro1969 camaro1969 is offline
Any additional details on this?
Vic
