Old 12-23-2015, 06:29 PM
rons69camaro rons69camaro is offline
Thanks guys! Where'd you locate the filter and Y block Will?
Old 12-23-2015, 06:31 PM
Y block is in the DSE shock channel in back and filter is basically right under rear passenger feet. Just behind the rear drain plug.
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 12-23-2015, 06:36 PM
Pics
Texas A&M BSME 2008
1992 Corvette ZR-1
Old 12-23-2015, 07:59 PM
randy randy is offline
we use 1/2 fuel stainless steel fuel line and flex lines from the hardline to the tank and engine. Both ends have a T off of them
Old 12-23-2015, 10:09 PM
Agree --- use SS tubing for the majority of the system and only use flex where you must. Just my opinion - but it's the way I do things.
Old 12-24-2015, 08:22 AM
Che70velle's Avatar
Greg, how do you go from SS hard line to flex line, meaning what fitting do you use in this application, on the hard line?
Thanks Dad!!
Old 12-24-2015, 08:29 AM
Use a 37* flare and nut on the hardline -- and a male/male coupler (actually called a STRAIGHT UNION) to transition to the flex.
Depending on the situation - it's also a good point to install a filter etc. With plumbing - it just depends on where you're at and what's needed in the system. It takes some thought and planning to have it turn out right.
