Old 12-29-2015, 05:10 AM
Vega$69's Avatar
Vega$69 Vega$69 is offline
I've run McLeod 3 times without issues. Do you have a stop on the clutch rod the the cylinder?
Old 01-04-2016, 08:56 AM
gmorris gmorris is offline
I had issues with Macloed bearings in the past as well. I went with an external slave setup from forte's because I was sick of dropping the tranny to change leaking bearings!
Old 01-04-2016, 12:33 PM
trevor572 trevor572 is offline
Hi. I'm about to fit a mcleod master and slave cylinders along with their firewall kit, I would really appreciate it if you could post some details or pictures of the stop you spoke of, sounds like a good idea and I would prefer not to have issues further down the track. Cheers Trevor.
Old 02-09-2016, 05:09 PM
DT69Cam DT69Cam is offline
Default McLeod
I just ordered their firewall kit for now. Will order the TOB later. I have read a number of leaks associated with the TOB and it does make me question if I should purchase another unit.?
69 Camaro Convertible (LS3/TKO in the works)
Old 02-10-2016, 10:22 AM
Chad-1stGen's Avatar
Chad-1stGen Chad-1stGen is offline
Why not run the stock GM throwout bearing? I can't speak from personal experience on aftermarket but I was researching master issues online a while back including Ls1tech and other sites and came across lots of recommendations for the stock GM throwout which is what I'm running with a tilton master.
I've only had the setup together for a relatively short while but it has survived 10k miles of which 1k miles is on the track (road course) as well as another unknown amount of miles on 20-30 autocross events.
Autocross and Track blog
Lots of autocross & track day videos of my car: https://www.youtube.com/user/TheDude023
Old 02-10-2016, 12:18 PM
Mr.VENGEANCE Mr.VENGEANCE is offline
from the information ive gathered so far from these posts many say either
go with GM or Tilton 6000
Im a little leary as I cant remember if I can get to the TB without having to pull the engine forward to get to the top bolt of my T56 magy.. I am SO hoping I can just unbolt the tranny and shaft and get to it..
I think I am going to go stock GM..
Old 02-11-2016, 06:19 PM
badazz81z28 badazz81z28 is offline
What trans? I say Oem slave
