Old 12-31-2015, 06:55 AM
Fair Fair is offline
Originally Posted by HotRod68Camaro View Post
next time meaning... later today?! Really like the detail and explanations so far!
Yes, I will be porting over dozens of posts today. We're technically closed today (Dec 31, 2015) for year end inventory, but I will sneak away to reformat and post here until I'm caught up with our latest entries. Over the weekend I will try to post what we've been up to lately which is getting pretty crazy...
Originally Posted by Schwartz Perf View Post
Nice work guys. I've been following some of your stuff on Facebook, and Heller is a friend of mine, we went to college together. Looks like he's doing some great work!
-Dale
Small world! Ryan is the man and heavily involved with all of our big customer builds. He made some custom long tube headers for a V8 swapped Miata we're working on earlier this week (below), which moved that build forward.
We see Schwartz goodies on Optima and Goodguys cars all the time. Good stuff.
More soon,
Terry Fair @ Vorshlag Motorsports
Old 12-31-2015, 07:05 AM
Small world indeed I remember seeing you around the car club in college station and at auto crosses.
I seem to remember there is a turn named after you on the way to Caldwell.
Glad to see you on here and amazing build so far! I can't wait to see more!!
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 12-31-2015, 07:43 AM
nicks67ca nicks67ca is offline
Nice work!
Old 12-31-2015, 08:01 AM
Neil B Neil B is offline
I'm loving these serious track car builds. Looking forward to seeing this one come together.
Old 12-31-2015, 08:48 AM
Project Update August 20th 2015: This forum post update covers much of the work we did from late May through mid June of 2015 on our customer's tube framed 69 Camaro "Pro Touring" track car. A little more deconstruction was needed, but for the most part that was all wrapped up and the real fabrication work really got underway in this period.
Before we get started I wanted to list the forums we're posting this build thread on. Note: The pictures in all of my build threads can be clicked for higher rez images or sometimes videos, but for some reason clickable images do NOT work over at S197forums.
One of these I own (vorshlag), two of them I sponsor (sccaforums + S197forums), and corner carvers puts up with my shenanigans (mostly). Later in 2015 a moderator from Lateral-G asked me to share it there, too. If there's another forum that would welcome this build thread (even with...gasp... watermarked pictures), and it has approval from an admin or moderator to post as-is, please PM me and I can port it over. Not that this is a ground breaking build or some unknown tech going into it, but its a fun Pro Touring / track build that not a lot of shops are willing to share the behind the scenes work on, to this level.
New Rear Suspension + Frame Section = Thoughts About IRS?
Once we had the new '69 Camaro frame rails laid out on the "frame table" we started looking at the rear suspension. It came here with a custom 9" Ford axle with a semi-finished 3-link (fore-aft control arms) and a Watts Link (lateral location), but it didn't look right. Sure enough, after Ryan measured the arm lengths, pickup points, and positions, then input the numbers into 3D suspension software, the the geometry was "less than ideal" for track use.
So by now we knew we would be massively changing everything out back - adding all new rear frame rails, altering the geometry and mounting points on the rear control arms, and making a new Watts using some of the old parts. And the solid axle housing was bare - it had no differential or axles installed. So a thought occurred to me... would now be a good time to discuss an Independent Rear Suspension?
We proposed both a C5/C6 rear transaxle and rear subframe/suspension for the 69 Camaro IRS
We pitched the idea to the customer, first showing him a C5/C6 rear transaxle and suspension, using the OEM aluminum rear cradle, arms, halfshafts, and transaxle. But he was invested in the custom ford 9" axle that was already in the build and didn't want to give that up. Plus after we measured a C5 in the shop we realized that an unmodified C5/C6 rear subframe and halfshafts would push the track width wider by at least 4 inches, which meant rear flares, and that would disrupt the original bodylines too much.
Custom IRS we built for a 99 Miata with an LS V8 swap = costly + time consuming
There are some aftermarket rear IRS setups but they aren't very.... good. Sorry, they are generally "Not appropriate for this application" - again, with massive Hoosiers making big grip numbers, and serious track performance as the end goal. So doing a completely scratch built IRS was an option, and we've done that before (on the Miata, above) but it would be a lot of custom work and added costs. We discussed the pros and cons with the customer and in the end we scrubbed the IRS idea, as this build was already too far along and LOTS more perfectly good parts would get chucked. So we got back on track and started diving into the new rear suspension geometry and frame rails.
Getting The New Frame Started
As I mentioned at the end of my last entry, the center of the chassis was built from 2x4" tubular frame sections, which were first fitted into the gutted unibody tub. These were then transferred to our frame table at the same width.
The existing aftermarket front suspension was added at the right location and tubing was made to join the "center" frame we built to the "front" frame sections from someone else. We don't know where this front frame clip came from, but it doesn't really matter. There are dozens of "bolt in" front suspensions for the 1st gen F-bodies and they span back over a decade, with lots of revisions along the way.
We had some serious reservations about some of the material used in the major suspension mounting point load paths, but the customer really wanted to use what he had. So we moved forward and mounted it to the frame table at the correct height, so we could do more mock-up and measurements.
Two things became obvious once it was joined to the center section and tack welded together. First, the maximum amount of negative camber we could get with this setup was -1.0° up front. Which is nowhere near enough, as these Hoosiers would probably generate enough cornering power to need closer to -2.5 to -3.5° up front. So we'd have to cut off the main upper control arm mounting plates, move them inboard, and figure out how to reinforce those plates to counter cornering loads.
Second, there were some surprising side-to-side suspension geometry inconsistencies in the lower control arm brackets of this production built front clip. These were going to already have to be heavily modified and beefed up anyway, but its just odd that the CNC laser-cut brackets could be assembled and be off by 5/8" from side to side. Again, we don't know who originally built this subframe kit, or if it was modified after it was installed, but it was a big hot mess.
So we now knew we had to remove the upper mounting plates and move them for more negative camber travel, then reinforce the flimsy plates heavily. Not to mention all of the control arm pick-up points were thin, poorly supported steel plate - everything needed to be heavily beefed up. The geometry wasn't good, the alignment capability was poor, and the engineering wasn't up the grip levels planned for this car.
continued below
Old 12-31-2015, 08:50 AM
continued from above
Watts Link and Aluminum Center Section
Many of the Watts Link parts were re-used in the new layout, shown below. The mounting tabs were super sketchy before, and looked like they'd fold up under hard cornering. These new mounts are stronger and will receive additional bracing and structure as the build progresses.
The solid axle had the mount for the center pivot of the Watts, as you can see above left. It was a decent looking mount and double-shear style football pivot, so those pieces were re-used. Since the rear frame rails and mounts for the Watts link changed, we had to alter the length of the lateral arms for the Watts. So those went from steel to aluminum lateral locating links; the old pics show black arms which are now gold anodized and adjustable length.
Next up was ordering the "third member" or "pumpkin" (rear gears + limited slip + bearing assembly) that bolts into the front of the Ford 9" rear axle housing. The housing was bare when the car rolled in here, so Ryan shared different available third member brand and material options with the customer and in the end we chose a Moser aluminum center section. Normally these are cast iron (nodular iron) but the Moser built aluminum third member is much lighter and plenty strong. Gearing calcs were done to pick the rear gear ratio that worked with the tire height (345/30/19 Hoosier), the gearing from the G-Force trans, and terminal speeds we expect the car to see at Texas road course tracks.
There are a lot of differential options for the Ford 9" but we chose a WaveTrac. We needed the third member in place to be able to know where to make room for the driveshaft, exhaust and such. Having Moser build and supply the entire assembly made it easy - they installed and setup the hypoid gear set, bearings, and differential into the aluminum housing - so that can be just bolted into the axle housing. We picked up some ARP studs and nuts for a Ford 9" housing and installed the third member shortly after it arrived (below).
New Front Subframe Fab
By now we are into work done in early to mid June. After the old front subframe was removed, additional 2x4" frame rail material was purchased. Ryan got to town and had the new rails cut and tacked in place quickly and began the front suspension mounting points.
The suspension used of a lot of pre-existing parts, including C6 Corvette aluminum uprights, aluminum C6 upper and lower control arms, and big disc brakes from Wilwood. There's a fabricated steering arm on the spindles, which was for the old subframe and rack setup. There was a haggard looking Fox Mustang steering rack kluged into the old subframe, but we knew that had to go (more on that next time).
Please note: all of the lower control arm mounts WILL be double shear. They are incomplete in the image above
Since we had other ideas for a more appropriate steering rack, Ryan left out some of the front structure - awaiting the new rack. As you can see the front has room for a bolt-in lower brace structure, which should allow for track-side service of the oil pan with the motor still in the car. Its a dry sump oil oiling system and pan, which still allows the motor to sit fairly low. The C6 control arms were mounted after geometry was again checked in simulation and placed where we could get some real camber and alignment settings appropriate for track use.
Again, the previous plate steel mounts were cantilevered off the frame rails and looked like they would not withstand the side loading that 315 Hoosiers could generate. We asked Ryan to tie the upper control arm mounting plates into the frame with tubing. The curved tubing wraps around the mounting plates and vertical 1-3/4" tubing will come up and tie across the engine bay. This will also be tied back into to the roll cage.
Before too long the motor and transmission needed to go in to make sure the front subframe frame rails left appropriate room to add custom full length headers (will show the construction of the headers in my next post). The placement and driveline angles were checked and re-checked then Ryan began working on the motor mounts. The driver's side mount is already installed in the image above, and you can see the digital angle finder on the tail of the G-force transmission as well.
continued below
The motor mounts use the same Energy Suspension polyurethane bushing we've used on hundreds of LS swaps, which is both rigid enough to prevent drivetrain deflection but just supple enough to cancel out some NVH. The mounts tie into the front frame/subframe structure and bolt on.
Above you can see Brad and Ryan test fitting one of three different racing seats the customer brought - a Sparco EVO III, an EVOII, and a Lajoie aluminum seat - which I will show next time. They also mocked up a driveshaft with 4" PVC tubing, to check rear crossmember clearance and tunnel position. There's some floor and tunnel structure started here, but I will show more of that in my next post.
A quick body mockup showed that meeting the desired engine setback would be easier to remove the factory cowl in favor of a fabricated part rather than just trimming it. Again, the firewall had been heavily modified (and yet had zero room for exhaust headers) and the rusty cowl was a mess, so losing all of that wasn't making anyone too sad. Plasma cutter made the initial, big cuts on the cowl, then the body could slide down over the chassis to verify fit...
With the body on you can see the engine setback clearly, above. The Norwood "alumi-fit" 69 Z28 reproduction aluminum front fenders and hood were also test fitted at this stage, to check basic clearances to the engine, tires, etc. Everything looked good and fit as expected.
That shot gives you a better image of what the car will look like when its done. It looks SO much meaner with the wheels and tires fitted, but I will show that next time.
Videos - This Week At Vorshlag
The 69 Camaro has made it into a few of my semi-regular "this week at Vorshlag" videos, and the one below get us caught up to where we stopped here in this build thread.
This June 15th Video has plenty of 69 Camaro at the beginning to about the 3:38 mark.
What's Next?
Next time I will finish covering the rest of the work knocked out in June and then some going into July, including: the differential install, more floor structure and tunnel fab work, dry sump tank mounting, more front suspension work, and firewall structure work. Oh yea, and the roll cage was built (teaser pic above). Until next time...
Cheers,
