Old 01-02-2016, 10:47 AM
Well, I don't like him cuz I'm jealous of all the shops he's gotten the opportunity to spend time with.
I'm sure he'd be happy to share that list of with you....
Old 01-04-2016, 10:37 AM
I see 2016 started here just how 2015 ended.
Ok, Happy New Year gents..... let's start off BMF 2016 on a better trajectory eh.
Old 01-04-2016, 11:37 AM
DBasher's Avatar
DBasher DBasher is offline
So before the "love" gets too deep I've got a serious question. The center frame section is new, are the rear rails? CorteX originally installed the watts and TA, is that all getting reworked? I know you've been in discussions with Ron Sutton.
Ok back to our regular shenanigans.
Happy New Year DG! What shops have you got in mind for this year?
Old 01-04-2016, 11:55 AM
Yes.
Yes.
Yes.
Ron Sutton on line 2.... gotta go.
Old 01-04-2016, 12:20 PM
57hemicuda's Avatar
57hemicuda 57hemicuda is offline
All Payton, and I can say is: You are welcome!!!! LOL
Old 01-04-2016, 12:29 PM
carbuff's Avatar
carbuff carbuff is offline
DG,
It looks like you are using the JRS axle housing, possibly modified to use floating brakes. I can't tell from these angles if you kept the JRS coilover and LCA mounts or replaced them?
And I presume that crossmember is the torque arm mount? What is the front mount going to be? Rod end, or will you use the 'football' style that JRS provided?
Finally, I spy a little Ron Sutton influence with the adjustable Watts mount in those pics. I really like the one Eric and I installed!
Keep 'em coming!
Old 01-04-2016, 02:09 PM
DG,
Keep 'em coming!
That is a JRS supplied housing. But it's Payton's. We traded since he is using a different one now and his original piece was more "matched" to what I am now doing.
The coilover and LCA mounts are a mixture of parts. Some of the simple stuff from Jake was just fine to use. Same with Cortex.
The X member is the torque arm mount yes with a removable section to allow for trans removal. The length of the new TA mandated this. The Cortex or and possibly the JRS piece would not have. Not sure what the front mount will end up on yet.
And yes Sutton is involved very much at this point. His watts link adjuster is such a neat piece.
I have just told Jim to use what he approves of in strength and design, or scrap it and build/source if otherwise.
TA design and install should be next. Then attachment of subframe to the "tank"
Old 01-04-2016, 04:14 PM
ALL OF THE ABOVE SUBJECT TO CHANGE.
PHOTOS MAY ONLY BE "REPRESENTATIVE" AND MAY NOT BE ACTUAL PARTS USED
Old 01-04-2016, 04:38 PM
[COLOR="Red"]ALL OF THE ABOVE SUBJECT TO CHANGE.
I challenge you to show me something on this site that isn't subject to change.
P.S. How's the fire sale going? That sounds like quite a .... change.
Old 01-04-2016, 07:39 PM
fleet's Avatar
fleet fleet is offline
True dat, but he'll probably be at 400K page views in a few hours...so we're obviously not a very discriminating bunch.
