Originally Posted by ibuildm
I sold one of these IFS units to a customer who is installing on a 69 Camaro. This is a dynamite piece. It is super ridgid with beautiful welding.
What do you base this off of? Does it
look rigid to you, or have you actually tested this in a real world situation?
He is installing a new 572 BB in it so it is going to test this suspension to the max. It uses NO Mustang II parts. The spindles are a heavy duty version of the spindles they have used on their coilover frontends for years.
How about using Mustang II
Geometry? Most people that use MII geometry don't actually use any real Mustang II parts either- They use chrome plated fabricated street rod replacements. Just like this frame appears to use.
It uses a manual rack and pinion as standard. A power rack with a quick 2.5 turn ratio is available also. It comes standard with a front sway bar. The standard brakes use GM metric calipers or you can upgrade to 12 or 13" Wilwood rotors and calipers. Combined with their new rear 4-link and subframe connectors and a good set of sticky tires this setup will make .9G's with ease.
Tim
Do you possibly know what the bumpsteer number are? How about camber gain, or initial caster settings?
IF this company's front and rear are able to pull a .9 lateral g on a skid pad, I'd give all the credit to the tires.
This is a hot rod front frame, looks dictated form on this item. If you are serious about open tracking the vehicle, this isn't your frame.
Tyler
