Old 01-12-2016, 05:32 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Originally Posted by JDODDS187 View Post
So I apparently do not know how to post pics....
It took me min to figure it out to. I was able to fix two of them for you. You can use the last of the four codes listed and just cut and paste as one option. The other is when you are typing out your post there is a tool bar at the top. Select the icon I boxed in this example.
There will be a pop up that looks like this:
Paste the link into that box and you're good to go. Make sure you delete the text highlighted in blue though. It's easy once you find the right button to push.
Curtis
Old 01-13-2016, 08:45 AM
JDODDS187 JDODDS187 is offline
Thanks for the help!
Cleaned up the underside then realized most of this sheet metal will be replaced due to rust.
[IMG][/IMG]
Old 01-13-2016, 08:50 AM
Detroit speed mini tub and new complete trunk floor
[IMG][/IMG]
Trunk floor was supposed to be Pre-notched.... turns out not so much..
[IMG][/IMG]
Need about another 3/4" to an inch on each side
