Old 01-16-2016, 01:42 AM
paulk68 paulk68 is offline
Originally Posted by SlowProgress View Post
You won't need a customer bolt here. There are several styles of all-metal locknuts that are shorter than the nylon insert style that came with the kit. If you cut the bolt down it will rust where you are missing the plating. I would just go to the local hardware store and find a shorter locknut.
So stick with the 2" bolt and find a shorter locknut. Yeah that makes perfect sense I am such an idiot hahaha I was so focused on the bolt size. Thank you!
