Old 01-20-2016, 08:56 PM
DFRESH's Avatar
DFRESH DFRESH is offline
Default Anyone using MTI's manual belt tensioner?
Guys, I currently have the HD tensioner from Magnuson that I know some of you are using, but still hear of belt slippage over 12 pds of boost.
I've looked around, but can't find many reviews on the MTI setup yet. Anybody here using one by chance? I've got an 8 rib pulley setup from Innovators West.
Current setup
MTI's Tensioner
Thank you gents!
D
Old 01-20-2016, 08:59 PM
WILWAXU WILWAXU is offline
I've used one of these on a NA LS setup:
http://store.katechengines.com/bille...sioner-p2.aspx
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
Old 01-21-2016, 09:20 AM
mikels mikels is offline
Thank you gents!
D
Cause is not due to belt tension - it's due to what you're asking an 8-rib belt to do.
12psig requires more power than you can feed through an 8-rib belt. Assuming that's a TVS 2300 rotor set (and not knowing your displacement and RPM) - you're asking for 100+ HP to be fed through 8-rib. Belt power transmission is dictated by contact area (rib count + belt wrap around pulleys) and tension. You'll never get enough tension to overcome the lack of contact area of 8-rib.
I've run many TVS 2300 blowers (GM, Magnusson, Harrop) and always needed 10+ rib (GM is 11) to feed that amount of power with minimal slip.
You can always go Gilmer belt drive - if you don't mind the noise.
Dave
Old 01-21-2016, 10:05 AM
Considering this is his other car, I don't think he'd mind a little noise.
Old 01-23-2016, 06:58 PM
DFRESH's Avatar
Thanks DG. I guess I could go the Kevlar Belt route on the street car. Why didn't I think of that?
Have seen plenty of guys running 16 pds with 8 rid setups---it's more of a reliability issue for me. Belt wrap and type of belt all play a part--as well as total surface are of a 6, 8, 10 rib etc. Was hoping someone here may have had some experience with a Maggie 2300 and manual tensioner setups.
Will keep moving ahead.
DF
Old 01-23-2016, 08:14 PM
Hope you and the family are well buddy. What Mikel's is saying makes sense to me. You can get away with anything for x amount of time.
Old 01-25-2016, 08:23 PM
DFRESH's Avatar
Same here Brother! Hope we can see you guys next time we are out your way---would be great.
Agree with Mikel also. Still hoping to find someone that has some experience with the aforementioned manual belt tensioner. If not, then I'll just keep moving forward with something else on the motor/car.
Hope you will be back into the car thing at some point. Hope I get out of the car thing at some point.
D
Old 01-26-2016, 10:06 AM
Chad-1stGen's Avatar
Chad-1stGen Chad-1stGen is offline
D
Blasphemy!
Autocross and Track blog
Lots of autocross & track day videos of my car: https://www.youtube.com/user/TheDude023
Old 01-27-2016, 10:30 AM
Jr's Avatar
Jr Jr is offline
Everyone on c5 says that ecs has "the best" tensioner.
Old 01-27-2016, 07:14 PM
D
Give me a call when you have your car all sorted out and you want to sell it really cheap.
Call me anytime you get out this way. It would be good to see you and the fam.
