  #15
Old 02-09-2016, 10:49 AM
andrewb70's Avatar
Originally Posted by Tony V View Post
I just want to clarify the above picture, and hopefully it doesn't lead to further confusion, but here it goes.
The connector on the left is technically PN 9440102, however vendors such as Mouser list it as being the same as PN 9440101. The 478 prefix is added by Mouser and indicates the manufacturer, in this case Kostal.
Ideally, you would use PN 9440102, but PN 9440101 works as well, if the oval circled cavity is hollowed out.
This information is straight from the Kostal blueprint, which is accessible through Mouser.
Andrew
