Old 03-13-2016, 08:22 AM
65 347's Avatar
65 347 65 347 is offline
You will not get 275 to fit between a stock leaf spring location and a stock quarter panel. Maier is 315 on all four corners but is running his suspension system which removes the leafs and he also has flares on wheel wells from and rear.
Sorry for the bad news but I've tried and it can't happen with out moving the springs
Mike
Old 03-13-2016, 10:38 AM
DBasher's Avatar
DBasher DBasher is offline
Mike
Mike, what size did you end up with?
Nik, let's see some pictures....where exactly are you rubbing? It sounds like out on the quarter panel, if so grab a baseball bat and have at it! How bad do you want it?
