Old 03-12-2016, 05:10 PM
Default carpet pad
I just spent about 16 hours removing a form of insulation like Dynamat from the front floor of my Camaro. It covered the area about the size of front floor mats. I never want to do that again, does anyone make a decent carpet pad that accomplishes the same thing as Dynamat?
Old 03-12-2016, 06:29 PM
Che70velle's Avatar
Are you looking for a noise reducer/vibration dampening product, or are you looking for a heat insulator product? Dynamat is a great dampening product, but doesn't have very good thermal insulation properties. Dynamat is mostly used to make a car quieter, and the downside is weight. The stuff gets heavy. There are products out there that do both. I used a combination of Dynamat, and Hushmat. The Dynamat for noise/dampening, and the Hushmat is excellent for thermal control. Be prepared for sticker shock...both products are expensive to do correctly.
Thanks Dad!!
Old 03-12-2016, 07:37 PM
The noise doesnt bother me the heat does, I just don't want to put something down that would be hard to remove. I will not use Lizard Skin or similar products, I was hoping to find a nice carpet pad that would to a point keep the heat to a tolerable level.
Old 03-12-2016, 08:41 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Let me know what you find. I am also looking for a solution to the heat. I have some Dynamat for the noise, but need something for the roof, firewall and probably the main parts of the floor. Gets silly here in Vegas.
Curtis
Old 03-13-2016, 07:55 AM
Sieg's Avatar
Sieg Sieg is offline
Maybe inspecting the underside of some of the newer performance cars will give you some ideas. I've noticed they typically address heat on the underside vs the interior. Such as heat reflective panels on the under-body or heat shields attached to the exhaust or under-body, or air flow ducting at the source similar to brake cooling.
Old 03-13-2016, 06:58 PM
Good thought Sieg
Old 03-14-2016, 07:04 AM
rickpaw rickpaw is offline
Good thought Sieg
DEI makes a product that applies to the bottom of the car to reflect the heat.
https://www.designengineering.com/ca...und-insulation
Don't have personal experience with that product though. Been thinking about using it for my next iteration of my Firebird.
Tu Ho
Old 03-14-2016, 01:31 PM
dontlifttoshift's Avatar
dontlifttoshift dontlifttoshift is online now
The floor and tunnel shield Rickpaw linked works great under the car.
Under Carpet Lite from DEI is what I have been using for insulation and it is pretty damn good.
Donny
Old 03-14-2016, 05:22 PM
Nativefx Nativefx is offline
I'm using dynamat throughout the car, including the roof, but I was also looking to utilize the Under Carpet Lite from DEI for the heat insulation properties.
Dontlifttoshift, can you tell me if you are using this in conjunction with the carpet padding already attached, or are you removing the padding and reattaching the UCL to the carpet in replacement? I'm worried about whether you could use both without to much "padding" under the carpet that would make it difficult to fit and also not look right?
Old 03-14-2016, 08:08 PM
minendrews68 minendrews68 is offline
I used a product called Ultra Touch, it's a product made from recycled blue jeans. It is 3/8" thick with foil on both sides. Fire proof and mildew proof. Really priced right too. I bought mine from Home Depot 4' x 25' long. I think it was around $60 shipped to my house. It's made in Arizona.
