Old 03-22-2016, 11:42 AM
fleetus macmullitz's Avatar
Twins are good.
Old 03-22-2016, 12:38 PM
Centerforce's Avatar
Centerforce Centerforce is offline
Originally Posted by will69camaro View Post
Center force. If I have issues with this spec. You can bet I'll be contacting you or a vendor about the dual disc you have!!!
Great! We're ready anytime you need us!
Old 03-22-2016, 05:42 PM
DOOM's Avatar
DOOM DOOM is offline
Will I have the CENTER FORCE setup for my car I'm hearing good things!!
Mario
USCOLLISION
Old 04-03-2016, 10:29 PM
I think I got pretty close.
I ended up making game time decision on adding a 4th button on bottom.
Still need to cut in the AC control then pull it all apart to paint it. Happy with how it's looking so far though!
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 04-04-2016, 05:25 AM
Sheck44's Avatar
Sheck44 Sheck44 is offline
Default VERY nice
Will, fantastic work ... I'm right behind you on the new dash setup and watching closely. Also, thanks for the heads up on the Modo door popper installation.
Cheers
Steve
'Build it RIGHT the 2nd time'
69' SS X11 PRO-TOURING - SOLD
73' FJ40 LS - SOLD
1966 FJ40 R2.8 -SOLD
911 Hotrod - SOLD
2002 Gated 360
Next up - "Killer Piggy"
67' Camaro - Take-Over'
Old 04-12-2016, 12:21 PM
Well fuse panel got mounted in the vintage air "shallow" glove box included in the kit.
Prob is there was no room for the massive Holley Dominator ECU.
Texas A&M BSME 2008
1992 Corvette ZR-1
Old 04-12-2016, 12:22 PM
So I decided only solution was to attempt to build a mount for the fuse panel and holley ecu. First stab at it i think looks ok, it serves as a new glove box, and was built with very minimal tooling.
Texas A&M BSME 2008
1992 Corvette ZR-1
Old 04-12-2016, 01:06 PM
It looks good Wil, nice job.
Old 04-18-2016, 04:41 AM
More work this weekend.
Took a break from the metal work and decided to modify the tail light buckets for the LED panels. Overall not too bad but the brackets that are included fit like ****.
Then decided to put the glovebox in the car and check fit and begin wiring (you can see rear light wiring already run to the trunk in previous picture.
Also ran the pain power cable. 2/0 welding cable. Pretty intense stuff and a beastly crimper needed to attach the lugs.
Picked up a product called Shine Seal from the original founder of Zoopseal in an effort to seal the raw aluminum I have in the engine bay. I cleaned all these panels and lightly brushed with a 3m pad.
Did the reservoirs also.
Lastly I started working on the Holley wiring and making good progress for a short amount of time. I hope to have this harness completed and modified for my setup by this weekend. Hope I can find the time to hit the garage hard this week.
Test fitting intake and verifying lengths of harness.
William
Texas A&M BSME 2008
1992 Corvette ZR-1
Old 04-18-2016, 10:26 AM
Frankenstine's Avatar
Frankenstine Frankenstine is offline
Default Wow
Great work William, Looking good,
