Old 03-22-2016, 12:09 PM
Project_Gotham Project_Gotham is offline
Originally Posted by Bowtieracing View Post
I have same system wich I bought many years ago. My car is still on project stage so I cant say anything on codes. How do you measure correct oil level?
I talked to Peterson and they said fill the system till the tank is 3/4 full while running.
I bought 3 gallons of oil. I used a welding rod to measure how deep the tank is, marked the rod where the top of the tank was, then measured where 3/4 full of that volume was on the rod. I used an oil primer to prime the motor since it was a new crate motor. You can also pull the coil pack connectors and turn motor over to prime.
--Mark Stielow Wannabe--
1968 Camaro SS
1969 Camaro SS
1969 Camaro LS7
2014 Chevrolet SS Sedan
Old 03-22-2016, 01:32 PM
Vega$69's Avatar
Vega$69 Vega$69 is offline
Pulling the coil pack connectors only to prime is not a good idea as you are still pulsing fuel. Disconnect power to the ECM then crank until you have oil pressure. Power the ECM and start engine.
Old 03-24-2016, 06:45 AM
Well Seems like my question caused Speedtech to revise their ATS LS7 oil pan instructions. Just want to say thank you to Blake Foster for helping me out. Thank goodness I do not have to re route all my oiling system.
The only difference in my system is that my oil cooler runs on the oil filter side like the stock LS7 pan does.
1968 Camaro SS
1969 Camaro SS
1969 Camaro LS7
Old 03-30-2016, 06:55 AM
Thank you and Speed tech for the help. Have you considered extra catch cans or is thete any use with petersen breather can?
63 Z06
Old 03-30-2016, 09:40 AM
gnx7's Avatar
gnx7 gnx7 is offline
I would check oil level like Gotham does. Welding rod while running.
My breather was also setup like they show.... outside the car.
