Old 04-21-2016, 02:37 PM
Shiner's Avatar
Shiner Shiner is offline
Default 10 Bolt 70 Chevelle- Weld RT-S 18x10 Backspacing
I am looking to put Weld RT-S S71 wheels on my 1970 Chevelle (2" drop) and 10 bolt rear end. The car will have Baer SS4 rear calipers.
I do not have a tool but I am wondering what my backspacing will be... I am not mini tubbed. I am wanting to do a 18x10 with a 315 tire but I am thinking of going with a 305/40 ET Street...
ALSO is anyone on here a Weld Dealer that I could get a good price on these wheels and tires?
Any advice?
Old 04-21-2016, 02:38 PM
Shiner's Avatar
modifications in siganture
1970 Chevelle SS
408 Forged LSX, LSA Blower, 4L80E, Ridetech HQ, Baer Brakes, Weld S71b
1997 Dodge Viper GTS
Heads, Cam, Bolt On's, BBS Wheels, Moton Suspension
Old 04-21-2016, 03:09 PM
It is best to measure for yourself since all cars are different.
From the cars we get in the shop the average is 5 3/4" to 6" back spacing. One was 5 1/2" but that was due to exhaust tailpipe routing.
Old 04-21-2016, 03:21 PM
Shiner's Avatar
If I have 15x8 5.5" BS and I like the way the fill the wheel wells and I then want to put a 10" wheel would I need to get a 7.5" BS(to accommodate for the 2" wider wheel?
1970 Chevelle SS
Old 04-21-2016, 04:17 PM
So a 15x8 and a 5.5 BS will actually take more due to tire bulge. Im assuming you are running a 255 tire? 255 on an 8 is 3/8" average. The actual back space available would be 5 3/4" taking the tire bulge into account.
On an 18 or 17 wheel the tire bulge is less.
I would measure what you have then subract an 1" min for articulation room. For a 305 or 315 on a 10" wide you will need 12" of space. Average 70 Chevelle wheel tub is 14-14 1/2" wide. 1/2" to the outer and 1 1/2" to the inner should do.
Jack up the back and pull the wheels. Let see what you have?
Old 04-21-2016, 04:22 PM
Shiner's Avatar
Wish you would just tell me, "Travis get the rears with 6" BS and the fronts with 5""
1970 Chevelle SS
Old 04-21-2016, 04:54 PM
Now what fun would that be.
Actually I would if you would let me measure the car first but you are going to have to get dirty to know for sure. You have everything there to get the answer you need.
With the tire on the car, measure distance from the inner well to the inner tire. Closest section to hit.
Now measure the outer tire face to the wheel well lip. Quarter panel lip.
Pull the tire off and measure the current tire width. Sitting on the ground on its side. Measure the width. Ground to the top of the tire. 8" wheel should be around 10-11" wide. This is the section width.
Now take a measurement of the wheel well to the quarter panel lip.
Now use a ruler and tape measure to measure wheel mounting (axle flange to inner wheel well) pictured^
let me know when you get all of that.
Old 04-21-2016, 05:07 PM
Shiner's Avatar
Will try and do it tomorrow, thanks Vince
Can you get me a good deal on some S71s?
1970 Chevelle SS
Old 04-21-2016, 07:53 PM
Che70velle's Avatar
The limiting factor on Chevelle rears is the lower shock bracket. It sticks way out toward the tire, and as you go with wider tires, your tires will hit the lower shock bracket before they hit the wheel tub. An 11" wide wheel is very doable WITHOUT the lower shock bracket in place, but of course this would require rear suspension mods.
Good info as always Vince!
Thanks Dad!!
Old 04-21-2016, 08:37 PM
JKnight JKnight is offline
That info on the Lower shock bracket should be useful when measuring too, easily overlooked if you're only focusing on the wheel tubs.
