Old 04-29-2016, 06:27 AM
paulk68 paulk68 is offline
Originally Posted by GrannyNova View Post
Got the v6 frame brackets off after a couple of hours. Added new poly bump stops to the lower control arms for the lower stance and new poly motor mount inserts for the V8 swap.
Got the Belltech shocks, poly sway bar bushings and endlinks, trans mount, and replace the fuel lines because of a froze fitting.
Looks great, can I ask how hard is it to replace the rubber mounts with the poly for your motor mounts?
Old 04-29-2016, 08:16 AM
GrannyNova's Avatar
GrannyNova GrannyNova is offline
Just drill the rivets and hit with a hammer and the pop apart but the real fun is getting the mounts unbolted from the frame.
Old 04-29-2016, 11:08 AM
Che70velle's Avatar
Ah yes, I remember that from my conversion. Fun it was!
Thanks Dad!!
Old 04-30-2016, 12:37 AM
GrannyNova's Avatar
I just remembered I never posted any results on the brakes.
Started to take apart the rear drums and found that one drum had parts fall out after taking the drum off and proceed to rebuild both sides with new springs and pads.
Then on to the front with the EBC yellow stuff pads and stock rotors which had the ABS ring on the back which I didn't up front just in the, so I just went to the local pick a part and got some ABS dust plates and bolted everything up.
Tested a few times and the average result was 112ft from 60mph and the brakes got hot but barely had any fade, but had a spongy pedal after about 5 attempts in a row which I figure is there is a little air and causing the fluid to boil.
I did some looking and that distance is better than some supercars of the day so I feel pretty good plus I can add rear discs and maybe get a few more feet out of it in the future.
