Old 05-02-2016, 07:22 PM
Panteracer's Avatar
Default Dreamin Ta's
Mikey
You need to come out and run at Crows landing
in two weeks. Good place to test also as they usually
have a test track you can run as much as you want for $20
Also close to home for you
Bob
Old 05-03-2016, 05:28 AM
SSLance's Avatar
SSLance SSLance is offline
So it looks like you threaded the bolts through the backing plate and then pounded a small piece of sheet metal around the head to keep the bolt from loosening when tightening the nuts on the bolts, is that what I'm seeing?
Why not just put a couple pretty good tack welds on the bolt heads to the backing plate?
I am afraid of having this same issue some day, with the monster muscle bar I'm running up front...I'm just waiting for the day those bolts pull out of the frame.
Car looks good, now get it finished up and go out and get some seat time in it!!
Lance
Old 05-03-2016, 01:15 PM
glassman's Avatar
glassman glassman is offline
Originally Posted by Panteracer View Post
Mikey
Bob
Yes. I plan on it. Now, if only i had a running car.....the tune is tomorrow (wed) so heres hopin its dialed by the weekend.....Sons weddin in our backyard in four weeks, prepping the house, then "no worky" on the house for 1.5 years.....Crows here we come!!!!
Mike
Old 05-03-2016, 03:01 PM
Panteracer's Avatar
Lance,
yes threaded thru... locktight red then the sheetmetal
Not sure how to use the new welder my buddy has at my
shop... need to get a quick lesson.... so just went with this for now
After 28 years these things were bouncing around.. if I have
an issue I can get to them now..Nutserts were a pain to get out
I have a big gash in my arm from the sharp rotor when trying to pry them out
Mikey,
yes time to go to Crows.. mine can run even if the hood is
not on it.. would like to get the gear changed but too much
going on at work right now
Bob
Old 05-10-2016, 02:39 PM
Panteracer's Avatar
So I finally weighed the car.. after adding the 5 point roll bar,
Disc brakes- still going to go bigger, 18" wheels with larger tires
out back, glass front end, hood, alum front supports, lexan rear window,
mono leaf springs, no side windows, sub frame connectors, hollow
front roll bar, alum fender braces etc I have saved 232 lbs so far
Car is at 3448 lbs without me in it... I know that's not the way
to weigh it but was how it was weighed at the good guys ride tech booth
a few years so I know it was accurate
I also just bought my folding bike so I don't have to walk a million
miles out at Crows landing this weekend.. getting old and the old
back pain goes right to the knee
Bob
Old 05-10-2016, 04:29 PM
glassman's Avatar
Now you have to customize that bike!!!
Cars tuned, almost ready too run, but gotta help down in LA this weekend with my oldest, wedding prep sturff....
Keep it sunny side up and Crows!! how a bout some pics??
Mike
Old 05-11-2016, 10:01 AM
Panteracer's Avatar
Mike,
I had a couple of other buddies wanting me to put
an engine on the bike also.... Hot Rodders
Might just run Crows one day to shake things down
as I have a million other things going on also
Bob
Old 05-11-2016, 07:05 PM
Nice work, Bob. Now go have fun beating on the car!
Old 05-11-2016, 10:58 PM
fleet's Avatar
fleet fleet is online now
Agreed.
Old 05-17-2016, 09:22 AM
Panteracer's Avatar
One of my Buddies is wanting a 455 for his girlfriend's car
So I brought two more motors from my old shop to the new one
to see what I have
1975 455 destroked to 428 but bored so 440 with carrillo rods, weisco pistons,roller rockers, etc.. crank walked due to bad scatter shield... all bearings bad
Built in Idaho
400 balanced, blueprinted but all stock items 1971 block
Rod bolt went out the side of the pan.. built in Oklahoma
455 1973 stock motor out of a junk car... spun bearing
Here we have 4 of the 9 motors this car has had over the years
so I thought a group shot before I start getting rid of them
Bob
