Old 06-07-2016, 04:42 PM
Centerforce's Avatar
Centerforce Centerforce is offline
Originally Posted by 64mali View Post
Got my Centerforce Dual Friction clutch in for good
Awesome! Let us know how you like it once the cars up and running.
Old 06-10-2016, 05:58 PM
64mali's Avatar
64mali 64mali is offline
Not super happy with the trunk floor pans I got. There's a couple subtle differences like an extra drain hole in the middle and the raised beads on the bottom ran too high in the back. They prevented the pan from sitting flush against the rear cross member. So I had to break out the torch and hammer and flatten them out. Other than that they fit good and I sectioned it in a way that from underneath you could never tell they were replaced. I can make the inside undetectable as well but I'm not going to spend a ton of time on the top because I'm gonna Dynamat the floor.
Old 06-10-2016, 06:01 PM
64mali's Avatar
Flattening them out on the end worked out well and most of what you see was covered by the cross member , including the butt weld
Old 06-13-2016, 11:21 AM
pro66tour's Avatar
pro66tour pro66tour is offline
With what you had in front of you, you have to be happy with the outcome. Looks like the rest of the build, CLEAN...
Old 06-14-2016, 11:54 PM
64mali's Avatar
Thank you pro66tour
Old 06-14-2016, 11:57 PM
64mali's Avatar
Finishing up the trunk floor. I spent a lot of time trying to make these aftermarket pans fit and hiding all the seems so you can't tell I ever put pans in it. It's taken a while but I'm happy with the progress so far.
This is the only visible seem and it cleaned up really well. Can't tell!
Little grinding and some putty
Old 06-15-2016, 12:00 AM
64mali's Avatar
And some primer
